Hi guys,
I accidentally acquired a 2005 E65 (E66) 760Li. The car had not been used for 3 years, had a flat battery and flat tires. I replaced the battery with a OEM spec 95Ah AGM battery and registered accordingly. The alternator is measuring 14.2v charging at idle.
Re-inflated the tires to spec and reset the Tire Pressure Monitor.
The car has no other error messages except PDC. Mechanically the car has no leaks or faults that can be seen. Went through the annual registration inspection without fault.
The error I get is " Dynamic Drive inactive, the car may lean... " red warning at every startup.
I removed all the fluid from the power steering / ARS reservoir and replaced with fresh CHF 11S fluid from the dealer.
When using INPA to activate the startup procedure of the ARS it always stops at the first check after ignition, where the computer wants to reset the zero point for the front sensor.
When trying to re-calibrate the sensors (F5) I can re calibrate the lateral movement sensor, but not the front and rear valves. The error message is "Fahrzeug muss stehen"
So it seems that the front and rear pressure valves cannot re-initialize because it thinks the car is not still?
Any ideas?
1995 E36 M3 GT #111
3.0L S50B32 EURO Single Vanos with ITB's and Twin Garret GT2252 Turbo
VEMS Standalone (www.vems.hu) most features enabled.
Brakes, suspention, rollcage, seats, harness, wheels and tires.
Did you ever figure this one out? You’re describing my car exactly. I just bought one that’s been sitting and I have the exact same problem.
I figure it’s the alternator since it’s not holding the voltage within expected range so I’m gonna parts canon that one first.
Update. Found the control module was bad. The short term 30 error stems from voltage leaking In the control module.
