Hi all,
I'm looking to achieve this stance on my 2002 BMW Z3M Coupe (s54). Currently, it's totally stock. However soon I plan on getting these wheels (https://ccwheel.com/gallery/1993-bmw...lassic-wheels/).
I'll fit coilovers first on the stock wheels and swap the wheels at a later date.
What coilovers are recommended for this car to achieve that stance? I was going to get KW V2 but I read somewhere they sometimes don't clear the wheels on these cars.
p.s I'm in the UK so it needs to be a brand available here.
Thanks!
I have kw clubsports. Depending on the wheel you get, the spring might interfere with wheel clearance. A way to avoid this would be to get a shorter main spring to raise the spring collar.
That's a shame. I just want to buy some and fit them, rather than mess around buying extra springs, etc.
The other very common approach approach is to buy spacers (and longer lug nuts or studs) to clear the spring perch.
Ok Thanks. I think I'll get some KW V3 then.
TCKline Racing uses Koni.
https://www.tcklineracing.com/index....y&Category=326
