I want to replace the cam gears on my 2009 328i n52. Is it necessary to lock the flywheel with the pin, or can i rotate the crank to TDC and place the cam jig on and remove the cam gear bolts and then loosen the tensioner to remove the cam gears and reverse order with new parts?
