Hey!
So I was in the middle of doing module updates on ista/p using a j2534, paid for 24 hour access and it failed about 50% the way through. Now I have no response from the car at all.
I have read many posts and searched lots. I am unable to get Winkfp to work using the passthrud option. So I知 not sure what I知 doing wrong here.
This is my way to work and I知 kind of screwed. Can anyone help me out? Pm or call or something
Thanks.
When you do CAS update key must to be removed from the ignition coil, I'm sure your ignition was ON?!
Try with WinKFP...
Sent from my SNE-LX1 using Tapatalk
I followed the instructions that ista said which was remove the key from the ignition
Are you able to help me with winkfp. I can稚 get it to recognize the j2534 and connect to the car.
Send me Teamviewer to check.
How do I do that?
Is there settings that I should be looking at ? I have winkfp 5.3.1 installed and it opens when I have interface std:obd but when I change it to passthrud is wont open.
Do you have K+DCan cable, for E series is good for update of all car without multimedia.
I don't know how to set PassThru, never done that.
No all I have is a j2534 passthru.
Just ordered a k+dcan cable. Should have it in a day or two. Is it just a matter of setting it up and plugging into the car and winkfp will work?
Also when I was doing the programming as if I had obd it stated I was missing a file. 080100CAS3.ipo. Does anyone have this file?
Issue resolved with the great help of Abel
Thanks to everyone that replied and helped out. Appreciate it!
