Results 1 to 7 of 7
Thread: e36 m3 Post-cat O2 sensor replacement question
    May 2019
    Knoxville, TN
    1997 BMW M3 Coupe
    I was out on a long drive last week, and ended up with what I thought was an exhaust leak; but in actuality I lost one of my post cat O2 sensors.
    I was going to replace it, and found that the midpipe has an o2 sensor adapter that unthreaded. Is this adapter piece common, and does anyone know where I can find a replacement?
    Mike
    Aug 2011
    Washington
    '97 BMW M3/2/5
    Our cars came without any type of adapter on them. Check to see if the O2 sensor without the "adapter" fits. If it does, those may be "non-foulers" which move the sensor out a bit so they're not in direct flow of the exhaust (supposed to extend life), and you can safely run without the non-fouler, or pick up new ones. Often found at local auto stores or online if you search for non-fouler.
    If the thread is a completely different size, then I'm not sure. Only guess would be they're SAE adapting to metric, or the wrong size altogether. Maybe someone else knows.
    Feel free to ask about my car:
    TRM Coilovers 560f/784r | Epic Motorsports Tune | Apex Arc-8 17x9.5 et35 | Wilwood SL-4 BBK
    M50 Manifold | ASC Delete | Dinan TB | Fan Delete | Power Pulleys | Dinan CAI |
    S54 Oil Cooler
    Z3 Rack | Crossbrace | 3.38 LSD | Dinan Strut Tower Brace | Bear Motorsports SSK
    SS Long Tubes | SS Race Exhaust |
    LTW Replica Wing | Motion Motorsport Underpanel
    OE GT Front Splitter | Rear Rollbar | Rear Seat Delete | BW Fuel Starvation Kit | And Really Old Paint
    Check out my YouTube channel for more DIY's and videos about my E36 M3
    Jun 2010
    NY
    1997 328i
    You can remove the non foulers, they aren't doing anything good. Drive it and see if any codes come up. If you do get a catalyst code you should then replace both pre-cat sensors (not the post cat ones).
    Use anti seize on the thread, don't get any on the sensor, torque to spec.
    Avoid Vogtland Suspensions! Rusted then failed!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to E36 M3 forum from E36 forum
    SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
    http://twrite.org/shogunnew/topmenu.html
    Aug 2013
    1999 BMW M3 Coupe
    The OEM replacement sensors just thread right into the bungs. Nothing else required. Just torque to spec, and apply some anti-seize if you like (though I think the new ones I did a couple years back came with anti-seize tape or something on the threads). You should be able to find the exact part numbers over on realoem. I did all four of mine not too long ago and have had zero issues since (and an improvement in gas mileage).
    Jun 2010
    NY
    1997 328i
    Also when you re-connect the rear sensors and if you get a code, I would start with a can of injector or complete fuel system cleaner like one of Royal Purple's products and see if that clears the code. Because it will help clean the cats.
    May 2019
    Knoxville, TN
    1997 BMW M3 Coupe
    Thanks for the help guys. I thought it was a different thread because it didn't seem like the O2 sensor was threading into the midpipe, but it was just a difficult angle to get at. It was a non-fouler....I removed it and I appear to be code free.
  1. E36 BMW E36 M3 post-cat O2 simulator
    By golgo13 in forum Engines, Performance Parts & Software
    Last Post: 01-28-2019, 02:54 PM
  2. Replies: 9
    Last Post: 04-14-2014, 07:39 PM
  3. How long does post cat o2 sensor replacement take?
    By Brimmer M5 in forum 1999 - 2006 (E46)
    Last Post: 06-26-2012, 12:22 AM
  4. E36 OBDII post cat O2 sensors.
    By Darwin006 in forum Engines, Performance Parts & Software
    Last Post: 01-09-2012, 12:20 AM
  5. FS: 2 low mileage E36 OBD2 Post Cat O2 sensors $100
    By Ali in forum Engines, Performance Parts & Software
    Last Post: 11-04-2008, 10:32 PM
