Hi all,
I just completed a RLS (rain/light sensor) retrofit on my E38 which was never equipped with either a rain sensor or auto headlights. The LCM was also replaced with a LCM IV and coded to the car. The auto headlights part works perfectly. My question, though, is how do I add the rain sensing wipers option to the GM3? Looking online, it appears I might have to modify the ZCS and factory options list. I've attempted to do so on my NCS Expert computer, however I haven't been successful. If there are any ZCS experts here who can provide input, I'd be very thankful!
I was able to find the option (S521) in the E38ZST.000 file and added the values in the SA number field (does 8+2 = 0? this may be my problem), but I've never been able to get the coding completed. It always errors out with a "faulty coding key" when trying to finish. If I change no numbers (just go through the ZCS coding process and provide the already installed numbers), coding works fine. Attached are pictures of my current attempts.
Any help would be much appreciated!
E38 1998 740iL DM24826 - Arctic Silver Metallic / Gray - 185k
Retrofits/Modifications: Bi-xenon lights with angel eyes and city lights, 750iL grab handles and rear interior lights, facelift kidneys, Euro front plate, 2001 tail lights, auto wipers, auto headlights, interior and exterior illuminated door handles, Steptronic, "Max AC" IHKA panel, comfort exit/entry, LED high beams, rear seat foot rests, footwell lighting, Avin Avant 4, Monsoon rear deck subs and door woofers, wireless charging, hydraulic trunk (coming soon)
E38 2001 750iL Sport DD74513 - Titan Silver / Black - 175k
BMW CCA # 573127
8+2 = 10 The 1 has to be added to the next column.
Trevor
01 749i sporty, build 12/00 "Sports Barge",S62
92 VW Corrado VR6,AAA
81 Delorean,B28F
81 VW Rabbit Pickup 1.8T,AWW
03 VW Passat wagon 4.0 W8 6spd
not informed on it but is that hexadecimal? as in A = 10 or 1010 in binary ?
new to me, I never could get the programs for the computer hookup to do much on the 1997 740iL.....
Got the ZCS coded today. Turns out you have to remove the last digit from each line when calculating new checksums, and 8+2=A as the ZCS is in hexadecimal. Now to find where in the GM to enable the rain sensor...
BMW CCA # 573127
