M52B28 (RK Tuned, Fresh oem Coil packs (have 5 good extras as well just have to find them), Stewart Warner Water Pump, ECS tuning light weight pulleys, metal thermostat housing, M50 manifold, Max PSI ICV hose kit, ECS Tuning silicone coolant hoses, Clutch Fan delete nut, Mishimoto silicone intake boot, will include ews stuff, harness, M50 Valve Cover, etc.) Have a couple spare sensors (Cam sensor, crank sensor, random shit) and gaskets (oil pan gasket, spark plug cylinder gasket) that I will throw in with the car as well as a drilled oil pump nut with wire. (WILL START PARTING THIS OUT NOW)
167,xxx Miles
$800 Delivered within reasonable distance
FULL DISCLOSURE THE HEADGASKET ***IS*** BLOWN…….THE CAR STILL RUNS WILL MAKE A VIDEO BEFORE DISASSEMBLY
Reinforced Rearend (Reinforced differential carrier with Delrin front diff bushing, eBay adjustable control arms, ECS poly subframe bushing kit, ECS Tuning Poly trailing arm kit, welded 3.15 diff w/ aluminum diff bushings, Upgraded diff bolt, ECS Tuning Steel Braided Brake Lines for Dual Caliper Brake System (Massive Lee Wilwood Rear Brake & Dual Caliper Kit )....also will throw in the front oem brakes and rotors which still have alot of life on them and steel braided brake lines - $1500 for everything
16x8 squared Style 5 wheels square set w/ good tires (powdercoated white but on the dirty side) - $350
ECS Tuning 20mm Wheel Spacers with extended studs(PAIR) - $80
Silver Project Pull back Handbrake w/ Wilwood .625 master cylinder with brackets welded to the mount to replace the factory handbrake and steel braided -3an flex line for Dual Hardline under car - $150
Clutch pedal setup, reservoir line, clutch master cylinder clutch hardline, neutral switch, brackets, etc - $150
E36 Sedan Roof Wing - 100
If you need anything else I haven't listed just ask. All parts will be removed within the next couple weeks, ***I CAN DELIVER OR SHIP IF YOU ARE WILLING TO PAY FOR IT***
***************$2500 for everything***************
is this a coupe? Looking for driver side door seal
interested in power pulleys, ICV, and coolant hoses
Interested in the water pump
I’m looking for quite a few things if you could please message me at +13868466040
Interested in the rear wing - sent dm Sent from my iPhone using Tapatalk
