My wife’s 2007 525i blew a hose and I replaced,
Refilled.
Now it’s overheating climbs to 240 plus
I can not get the coolant vent procedure to actuate
Is there a manual way to trigger it?
Is there a maintenance mode for the car?
Only code showing is a camshaft sensor
I know the pump is working and I can see the thermostat open.
Yea there is a way something about pressing the gas pedal to the floor, google it how do you know the thermostat is opening
Right. It’s not actuating when I try that process.
Check that the ignition is fully ON (not just accessory mode) when you are doing the process. I think you have to push the start button twice without the key in the ignition to get there.
BTW, a fellow member reminded me on another thread that you can activate the procedure using ISTA or INPA if you have them.
So I found a fuse blowen.
The bleed process is working now
But the exact same symptoms
I want to sell the car at this point
Maybe bleed a couple more times. I’ve found if there’s been a big leak then there can be big air bubbles that take several bleeds to fix.
At this point tow it to a shop and have it looked at then sell the car
I suspect it’s a bad pump.
I paid 120$ for it.
I ran idpa and the pump tests @ 0%
New orelies $ 450
Goes in tomorrow
I’ll report back.
New pump fixed it !
Lesson learned
Don’t buy cheap electric water pumps.
