Results 1 to 2 of 2
Thread: Mysterious loss of power on s50b32 when hot
    Lebanon
    E30 M3 S50B32
    Hey guys,
    There's an odd problem happening. The car has developed a slight misfire/bog when doing part throttle, and it feels like it has a lot less power.
    The interesting part is that if i do a cold start, and shortly after punch it in 2nd on a slippery tarmac, it will go sideways as usual, after 5-10mins it starts to lose power, then if i try to get it sideways around a corner mid corner it will stop spinning the wheels in 2nd. It feels like there's a ton less torque/power.
    I've put the DIS program and ran a VANOS test, it passed. While driving i took a look at the values, it quickly jumps to the "nominal" value for both cams.
    There are no fault codes in the ECU.
    I checked the fuel pump pressure while hot, it's good at 5bar.
    The spark plugs aren't that old and when i remove a coil the car will misfire on that cylinder.
    I was just searching for how to diagnose a bad coil when i saw this thread https://www.e46fanatics.com/threads/...e-help.851278/
    and i saw this post by someone "Ok! I think I have a powerloss of at least 30-40hp. When it is cold and I floor it the rear wheels spins, but when it is hot it is not even loose traction when it is wet in first gear...."
    He also has replaced vanos, coolant/ECU/air temp sensors, 3 knock sensors, etc etc.
    Anyways hopefully somebody can shed some light on the matter. I was about to get another coil i had and start switching it between cylinders, and there are 2 spark plugs i couldnt check due to the coilpack nuts seizing, although i replaced all 6 not too long ago. Those are my only leads.
    PS: around 2 years ago, the car lost a ton of power on the lowend (way more than currently), i thought it was vanos related and i changed the intake cam sensor, then i found out the exhaust solenoid wiring had become unsoldered, so i soldered it back, and the car worked again.
    1987 BMW M3 S50B32 engine swap
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Hows it performing?
    88M3 AW 43k miles Project FS
  1. Rough start when hot followed by a severe loss of power E38
    By mike789 in forum 1995 - 2001 (E38)
    Last Post: 05-21-2010, 09:13 PM
  2. 2002 330xi loss of power when hot ....?
    By kbeemer in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-31-2009, 01:08 PM
  3. Loss of power when hot!
    By BMW 528 in forum 1996 - 2003 (E39)
    Last Post: 08-19-2008, 01:53 PM
  4. 99 323i loss of power when hot
    By VoCS75 in forum 1991 - 1999 (E36)
    Last Post: 05-12-2008, 08:23 PM
  5. Mysterious Loss and Regain of Power
    By Damaskus325 in forum 1983 - 1991 (E30)
    Last Post: 09-08-2005, 05:00 PM
