Where does this attach to? It comes from the same wire bundle that has the oil pressure switch wire. I can't seem to find a male connector that it goes to.
https://hosting.photobucket.com/imag...2356262133.jpg
I assume it is for the 1993 E36 325i, will move it to the E36 forum
It's for the 1979 320i
then I move it again to the right forum, always mention model and built year
That goes to the condenser on your distributor. Tach signal and points ground.
The wires may reach easier if the ignition distributor was properly orientated.
And welcome to the forums.
click to enlarge the picture.
Tbd
Almost
Tach signal and Ignition Coil (-).
Here's a pdf copy of the '79 320i electric manual. Please save a copy.
http://www.findmymerchant.com/images...l/ETM_1979.pdf
Tbd
