Hi, i am having current problems with my EWS. the car didnt come with a key when i got it, is there any way to disable the EWS/Immobiliser.
I am pretty sure it is a EWS2 (black box with white connector) and a BOSCH DME Ver. 1 247 851
Thanks alot, could really use some help with this one. i am new to BMW's
What's the production date of your car? Where did you get your current key? Did that key ever work in your car?
hi, its a 04 1995 3181
The story is i got it from a dealership for real cheap but the catch was that it came without a key... so i never had one to begin with. I have found a way to access the ignition without a key, just need to bypass the EWS to get spark/fuel/turnover
thanks
i hope someone can help cause i have the same car same year automatic & i have master key but the side doors wont let me twist over to unlock or lock but i can unlock the trunk and open the glove box so idk bro,in your case ive seen places like small shops that can make keys for the low,try looking in the area ?
i had someone look at it, and they said it dosent have a ews system? and i have undone the barrel and turned the ignition manually without using a key and i still have nostart? im starting to run out oif ideas
Instead of going through all the BS you're going through, just call the dealer , they can get you an already cut key with the proper chip in it for around $90.
