This is a part-out of a 1999 BMW M3, ~190kmiles. ***Engine, transmission, driveshaft, and differential have all been removed*** I do have some accessory parts available. The vehicle hit a wall on the left side and was too expensive to repair.
The following parts have been removed, or are damaged:- Engine, mounts, and wiring harness
- Transmission, shift knob/boot, driveshaft and differential
- Power steering rack
- Rear bumper cover
- Left rear quarter panel
- Side skirts
- Left front quarter panel
- Front bumper cover (some trim pieces still good)
- Front grille assembly (kidney inserts still good)
- Left foglight
- Left taillight
- All audio components
- Windshield (not from accident)
The driver door was not damaged. The driver side airbag did deploy. The left front control arm was damaged, which pushed the wheel assembly forward. I removed and inspected the strut and found that only the threaded part of the shaft had a slight bend in it.
The following parts are in great shape given age of vehicle:- TC Kline Single adjustable coilover kit - 600# spring rates (40k miles)
- UUC adjustable rear control arms
- Power vader seats - SOLD
- Rear seats & interior panels
- Carpet
- Headliner (replaced 3 yrs ago)
- Dash
- Steering Wheel
- Glovebox -SOLD
- Climate control module (all lcd’s work)
- Check control module (all lcd’s work)
- Gauge cluster (all lcd’s work)
- Door panels (slight wear on driver’s handle) - SOLD
- Center console/armrest
- Hood
- Both doors & window regulators (barely used)
- Sunroof assembly
- All side & rear glass
- Right side wheels & tires
- Trunk lid
- Headlights
Anything else in the photos is available unless noted above.
https://drive.google.com/drive/folders/1El0E991N0Aox8NUUWlxtvuzcEI78gKw2?usp=sharing
