I bet you can open it without having to go that far. Take off the pull handle, and the trim panel covering it. Take off the trunk release unit thing, and disconnect the cable from it. Using a pair of pliers, pull the cable, holding the sheath (black outer part). The hood should open. Then replace this cable unit. The black outer part gets messed up, and when you pull the release handle, it pulls the outer part with the cable, and won't actuate the release levers.
