Hello i have an issue with my car, just got it from a private seller . When I bought it it had an issue with cluset , dials no work on them so i ordered a new dcluser on ebay. Swap it all works good on this one but when i plug it in it give me , airbag , seat belt and dynamic drive fail , if i swap back to orginal dash no errors . Some one tryed to code it but it faild , when i came home i just realized is not same part number and the board inside the cluster is diferent .Any ome have any clue what can be wrong ?
The cluster will also have an error for the odometer. It should show up as a dot after the miles.
Use a scanner and clear the alarms. You have to drive for a few minutes for the alarms to clear; if it was coded correctly.
