Results 1 to 4 of 4
Thread: F01 Oil Consumption
    Sep 2016
    West Chicago
    2013 BMW 328i Xdrive n20
    F01 Oil Consumption
    knowing that these F01s eat a lot of oil due to bad valve stems will the car let me know if there is low oil or no oil like an indicator or warning? I would hate to find out by the car seizing any help would be appreciated thanks!
    The engine is equipped with an oil level sensor. It should alert you when the oil level is low. BMW issued a bulletin years ago stating to add two quarts, and not just one, when the low oil level light shows up on an N63 equipped vehicle.
    Jan 2016
    Ca
    2001 525it
    I would check the electronic dip stick, yuk, regularly
    Philadelphia
    BMW 740i
    Hello, I have a 2009 BMW 750li. When I try and check my oil with the Idrive, the system say "inactive", so I cannot check my oil. Is it safe to assume that I need to have the oil sensor replaced? Thanks for your help. Bill
  1. What could be causing high oil consumption?
    By C///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-22-2021, 12:36 PM
  2. Oil Consumption!?
    By ///M Rod in forum 2001 - 2006 M3 (E46)
    Last Post: 03-23-2003, 04:51 PM
  3. M42/M44 oil consumption pattern?
    By hccyong in forum 1991 - 1999 (E36)
    Last Post: 07-24-2002, 01:56 PM
  4. 3.0L oil consumption
    By abellofi in forum 1999 - 2006 (E46)
    Last Post: 03-21-2002, 01:35 AM
  5. Oil Consumption
    By tyl in forum 1992 - 1999 M3 (E36)
    Last Post: 11-19-2001, 07:23 PM
