Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 5 of 5
Thread: 73.1 hub bore work with 72.5 hub bore?
    Jun 2020
    Tampa, FL
    1998 BMW 2.5 Z3
    Got a 98 Z3 i6 I'm shopping wheels for and was told a hub bore of 73.1 wheels fits on the BMW 72.5 ?
    Is this correct or is the wheel shop pushing a sale? I know is only like a mm off but I feel like that's important.
    Car is a kinda daily/ but mostly weekend car.
    Ty for the help!
    Aug 2011
    WA
    '97 BMW M3/2/5
    That is not ideal. They make hub spacers though that enlarge your hub size to fit the larger bore of the rim you are putting on. You can get them in plastic or metal. You are sure it's a hub bore of 73.1 and not 74.1? 74.1 is more common in 5x120 for BMW's since it's what E39's have.
    I've ran plastic ones for my winter set of Style 5's to get my E36's 72.5 hub size to the E39 74.1 for three years without having to replace them. The best route is to just buy the correct rims to begin with, having the correct bore size.
    Feel free to ask about my car:
    TRM Coilovers 560f/784r | Epic Motorsports Tune | Apex Arc-8 17x9.5 et35 | Wilwood SL-4 BBK
    M50 Manifold | ASC Delete | Dinan BBTB | Fan Delete | Power Pulleys | Dinan CAI |
    S54 Oil Cooler
    Z3 Rack | Crossbrace | 3.38 LSD | Dinan Strut Tower Brace | AKG Chassis Mount Shifter
    SS Long Tubes | SS Race Exhaust |
    LTW Replica Wing | MM Underpanel | CF Sunroof Delete
    OE GT Front Splitter | Rear Rollbar | Rear Seat Delete | BW Fuel Starvation | Turtle Labs Door Panels
    And Really Old Paint
    Check out my YouTube channel for more DIY's and videos about my E36 M3
    Jun 2020
    Tampa, FL
    1998 BMW 2.5 Z3
    Hey thank you! According to the site they are 73.1, I will call them, the retailer said the difference is so small it won't matter :/
    But it was just a customer service rep..
    Quote Originally Posted by Carpy2 View Post
    Michigan
    2005 325Xi
    It will matter just enough to cause a vibration. Maybe.
    BMWs center their rims on the flange of the hub, and not by using the lug bolts. It might not matter, but it won't be because "the difference is so small". That 0.6mm difference may as well be a foot (sorry, a meter). A vibration caused by lug-centering the wheels can be because it is off-center by less than 0.6mm.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    NW suburban Chicago
    hiss by my window
    Are you sure the wheels offered aren't 74.1mm?? 74.1 is the E39/X5 hub size, lots of aftermarket wheels use that hub bore as its easily corrected with hub rings and makes stock keeping easier with one "BMW" fitment. Hub rings to make up the difference are readily available, I like the plastic as they are quite thin. The aluminum ones rot and stick if your roads are salted. Ask the seller to throw them in.
  1. Boring out a wheel hub..
    By matt4471 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-15-2011, 07:26 AM
  2. Boring out a wheel hub..
    By matt4471 in forum 1996 - 2003 (E39)
    Last Post: 12-15-2011, 01:03 AM
