Results 1 to 19 of 19
Thread: 2002 S54 BMW Z3 M Coupe
    Jun 2020
    UK
    2002 Z3 M Coupe
    Hi,
    I just got a 2002 BMW Z3M COUPE (s54). I have various plans, first to get a PPF wrap and then fix the ride height and seating position, who knows after that.
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Pictures didn't show up for me...
    Wheels look awfully light for an 01-02 (refinished Hyper Silver instead of Chrome Shadow?) but the rest looks nice.
    McLean, VA
    02 MC, 01 MR, 99 Z3C
    I can’t see images either. I just refurbished an 01 M roadster including the brakes. Even with track driving, the stock brakes are more than adequate as long as they are well maintained - fresh brake fluid, lines in good condition, appropriate pads, etc. At 87 k miles, I found that two of the four calipers were sticky so I just replaced with OE remanufactured units. After I returned the cores, it was actually pretty affordable. I installed Zimmerman rotors and Cool Carbon pads which dust a bit less than stock.
    Kelvin
    Jun 2020
    UK
    2002 Z3 M Coupe
    I just got the car back from the following doing:
    - Some paintwork fixing
    - Paint correction
    - Paint Protection Film wrap all over
    - Carbon coating applied
    Next plans are:
    1. Remove the stupid looking number plate holder on the front. How do I do this?
    2. I'm very tall and the seating position sucks, I read online about a seat tilt kit but cannot find this anywhere actually for sale :/
    3. I've ordered this renown steering wheel to hopefully stop the wheel from touching my knees constantly https://blackforestindustries.com/pr...29696904265772
    4. Fit suspension. I was thinking KW V3 with a 15mm spaced on the back and 12mm on the front.
    Jun 2020
    UK
    2002 Z3 M Coupe
    And here's a recent photo
    McLean, VA
    Still no pics....
    There is a thick piece of padding behind the carpet behind the drivers seat. You can trim some to give you more room to move your seat back further.
    If the license plate holder is OE, then typically mounted by two screws along the top edge of the plate.
    Seat tilt mod kit sold by Bimmerdiffs which is run by a forum member
    https://www.thayermotorsports.com/co...ns/interior-z3
    Kelvin
    Apr 2002
    Florida
    Coupes...
    Quote Originally Posted by odwyerracing View Post
    You are wasting your money. Get some H&R sport springs and Koni Yellows.
    You will be happier with the ride comfort in the long run and it will be better on your car's structure.
    Replace ALL the bushings, especially the strut mounts. They are hard as a rock. Get new OEM strut mounts, stay away from camber plates if you value your investment.
    You don't need a spacer up front, you can get 17mm spacers from RE that are cheap and good quality.
    Seat tilt mods are just grade 8 coupling nuts with short grade 8 bolts.
    White is Right, Steel Grey is OK, but Estoril is the only color that truly matters.
    I like Coupes.
    Jun 2020
    UK
    2002 Z3 M Coupe
    Quote Originally Posted by KBH22102 View Post
    Still no pics....
    This forum seems to break the images, here's a direct link https://i.imgur.com/lrM7heS.jpg
    That kit amazon links say unavailable
    Quote Originally Posted by mpire View Post
    Can you provide a link to "H&R sport springs and Koni Yellows."?
    Also define "ALL bushings" as I asked powerflex a quote for all and its around £800...
    Part Number Product Description
    RRP Each GBP
    Qty Req'd
    Total exc VAT
    Total inc VAT
    PFF5-301BLK Front Lower Wishbone Rear Bush
    £22.95
    2
    £45.90
    £55.08
    PFF5-310-23 Front Anti Roll Bar Mounting 23mm
    £16.45
    2
    £32.90
    £39.48
    PFF5-4650 Engine Mount
    £135.95
    2
    £271.90
    £326.28
    PFR5-300 Rear Diff Mounting Bush
    £25.95
    £25.95
    £31.14
    PFR5-306 Rear Trailing Arm Bush
    £24.45
    4
    £97.80
    £117.36
    PFR5-311 Rear Beam Bush
    £34.95
    2
    £69.90
    £83.88
    PFR5-504-19 Rear Anti Roll Bar Bush 19mm
    £14.95
    2
    £29.90
    £35.88
    PFR5-5630-10 Rear Shock Top Mount Bracket and Bush 10mm
    £36.95
    2
    £73.90
    £88.68
    £777.78
    Also, why don't I need a spacer upfront?
    Re: the seat kit I'd rather buy a kit with simple instructions as I'm not a mechanic.
    Jun 2020
    UK
    2002 Z3 M Coupe
    Is this the suspension setup you were referring to? https://www.demon-tweeks.com/uk/koni-sport-performance-suspension-kit-kon1140-3432/
    edit:
    also, they're not at all adjustable? if so, that's not what i want
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    On the coupe, this piece of carpet goes all the way to the hatch. I still couldn't get access to the padding under the carpet even when nearly the whole interior was disassembled when I was doing the hear shock top mounts.
    I think the center console, seats, and trim would all need to come out in addition.
    Feb 2016
    Philadelphia
    2001 BMW M Roadster
    - Paint correction
    Next plans are:
    KW V3 is definitely not for the faint of heart. And not ideal for the street. But that's how I purchased mine and it was newly installed when I purchased, so I'm not changing it. Definitely handles like a dream though.
    2001 BMW M Roadster - Steel Gray over Imola Red/Black (1 of 8), Eisenmann sport exhaust, KW V3 coilovers, Strong Strut engine brace, Randy Forbes subframe reinforcement, GSR Technik tune, 3.64 Torsen LSD...Weekend toy!
    Jun 2020
    UK
    2002 Z3 M Coupe
    Quote Originally Posted by spikeisgr8 View Post
    Know any alternatives? All I care about is:
    1. They're adjustable so I can get the stance right
    2. They're not too hard, i want stock-like feel
    3. I can buy them in Europe
    edit: ordering kw v2
    Washington, D.C.
    S54 e36/8
    Almost everyone here will recommend TC Kline Coilover packages. DA if you can afford them.
    Apr 2020
    Ankeny, IA
    96 BMW Z3
    I want the stupid looking front license plate holder if you care to part with it. Here in Iowa it's needed for the stupid looking front license plate. I'll pay shipping and a reasonable price if you're interested.
    Claude Berman, 96 Z3 Production Date 2/96 BMW CCA# 581686
    The only good is knowledge and the only evil is ignorance. Socrates, 469–399 B.C.E
    Washington, D.C.
    S54 e36/8
    Quote Originally Posted by cyberman View Post
    If he's in UK, it's not going to be the US Size one. I have a Euro one, it's long and skinny like their plates, not a typical US rectangle plate mount.
    Just go with a tow hook mount, go mini go or whatever people buy these days.
    Apr 2020
    Ankeny, IA
    96 BMW Z3
    Oh, thanks - didn't realize you have those really funny looking plates.
    Jan 2005
    Rothesay NB/Bucerias Mx
    2000 Z3 m coupe
    To “fix” the seat for a tall person...
    You use a sharp knife to access the area behind the seat.
    Remove as much of the styrofoam bulge as you wish, push the cut “shut” ( don’t remove carpet...just cut to permit access to the bulge).
    Refit the carpet.
    You won’t see the cut once the seat is pushed back ....next raise the front seat mounts approx 1/2-3/4 “
    You can just buy one yourself, look up tow hook license plate mount
    PRICE CUT on ALL FABRICS
    Jun 2020
    UK
    2002 Z3 M Coupe
    Minor update:
    I removed the stupid looking front license plate holder, which did look like this:
    https://www.grooms-cars.co.uk/wp-con...m-coupe-01.jpg
    And just stuck the plate to the front directly, looks much better IMO
    https://imgur.com/a/SFX7PJf
    I did experiment with some vinyl front plates and they were too low quality to even fit successfully.
    Also this week the car goes to a specialist to:
    - Check out why my dash is full of warning lights..
    - Fit new steering wheel
    - Adjust the seat so I can fit in the car
    KW suspension is still on order.
    Once that stuff is done I'll be driving all around Europe in it for a month or so.
  1. Replies: 0
    Last Post: 09-02-2016, 12:00 AM
  2. Replies: 0
    Last Post: 09-01-2016, 11:37 PM
  3. Z3 E36/7 2002 BMW Z3 M Coupe S54 Track Car
    By LAWLence in forum 3 series & Z Series
    Last Post: 01-01-2014, 09:29 PM
  4. FS: 2002 BMW Z3 M Coupe (S54)
    By TCahn in forum 3 series & Z Series
    Last Post: 06-23-2013, 12:35 AM
  5. 2002 BMW Z3 M Coupe - $29500 (santa rosa)
    By CaliAgents in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-14-2009, 11:15 PM
