Results 1 to 4 of 4
Thread: Getting EasyDIS working - can't connect to car
    Williamsburg, VA
    85 380SE 5.6, 99 540i/6
    I have an earlier post about head emulator that can be ignored, I see in the many years since I last did this that is no longer the way.
    I need to get DIS V44 connected to code a mk IV nav system. I have the v44 working and I have IFH service (though it just runs in the background, I thought there should be some kind of window for it?) and I have done everything in the David MC Read This First PDF, but I still don't have DIS recognizing the car through my USB-OBD connector (which is a connector that works fine for me on a separate machine that has a purchased pre-setup V57). What's the next step? No Free Diagnostic Heads show in the connection setup menu, which I'm assuming is the root of my problem.
    EDIT: Going the diagnostic head emulator route because that has worked for me in v57, but here's where I'm getting stuck: when I go to add in the IP address for diaghead in the unix root, whether I do init 0 or init 6 after it shuts down from that my DIS won't boot anymore, I can a restart loop with the server X message.
    Jun 2022
    Wisconsin
    E46
    Same problem, can't reboot DIS after updating diaghead ip's in unix.
    Any updates?
    Williamsburg, VA
    Quote Originally Posted by Verdant View Post
    Any updates?
    Nope, I never was able to get it working again.
    Jul 2004
    Houston, TX
    36 Cylinders
    While I understand some like DIS especially for diagnostic purposes for the test plans (although on some of these ISTA works perfectly well); for coding, why not simply use NCS Expert and call it a day?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  1. Wirelessly connect to car
    By kramgam in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-08-2007, 01:15 AM
  2. windows not working? and problem starting the car..
    By bmwaddicted49 in forum 1983 - 1991 (E30)
    Last Post: 12-04-2006, 01:23 AM
  3. Replies: 3
    Last Post: 11-09-2006, 07:33 PM
  4. Replies: 22
    Last Post: 06-03-2003, 05:25 PM
  5. Work start date on my car (5-24)
    By BetaTested in forum 1975 - 1983 (E21)
    Last Post: 05-21-2003, 09:34 AM
