Results 1 to 11 of 11
Thread: 1988 735i Can't get oil or service reset to clear by shorting pins 7 and 19
    Feb 2018
    Belmont, NC
    1988 BMW 735i
    Previous 'brake pressure' and 'check engine' alarms cleared by themselves when I corrected the respective causes. However, have tried several times to reset the oil and service resets to no avail even after disconnecting the battery and trying again. Do the 'brake pressure' and 'check engine' codes have to be cleared in the ecm first? Also, have never been able to get the stored codes, or any thing else, to appear by using the stomp method.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    brake pressure warning and check engine go away when fault repaired after xy restarts of the engine
    o reset the service indicator after performing an oil-service or an inspection:
    1. With the ignition off connect pin 7 (SI reset) with pin 19 (gnd). Remember to fuse this wire or to use a resistor just to be safe.
    2. Turn the ignition to position 2.
    3. Pull the wire out after about 5 seconds to get an oil reset or 10 seconds for an inspection reset.
    3. Now replace the cap on the diagnostic connector.
    4. Turn off the ignition.
    http://bmwe32.masscom.net/johan/tips..._connector.jpg
    https://www.youtube.com/watch?v=aWLBXHYgM1M
    what month/year is your car? US spec model or different country? Only US spec cars have this feature to get stomp codes. Very early DME's like the M1.1 built within 1987 and early 1980 had such problems even when it is US spec that they could not make a stomp test, I have read. Pelican parts says 735i/iL E32 M30/B35 86-88 0261200 150 Bosch Motronic M1.1, 735i/iL E32 M30/B35 (211hp) 89-92 0261200 179 Bosch Motronic M1.3
    The old DME M1.1 has only a limited space to store faults anyway.
    Motronic 1.1 1987 to 1988: The ECU will store a maximum of 5 fault codes. Motronic 1.3 from 1989: The fault code memory is extended to contain all fault codes that are detected by the EMS. In vehicles sold in the USA, when the ECU detects that a some faults are present it earths pin 15 and the Check Engine warning lamp on the dash will light. The lamp will stay lit until the fault is no longer present. A warning lamp is not fitted to vehicles sold in other markets. The faults that will turn on the lamp are mainly those concerned with emissions. Other faults are logged by the ECU but the lamp will remain out. More here https://mafiadoc.com/bosch-motronic-...29f484448.html
    Feb 2018
    Belmont, NC
    1988 BMW 735i
    My 735i is a 10/87 build. I've tried the steps above several times and still can't get the oil/service to reset even after leaving the shorting wire in for a couple minutes or so. That's why I thought maybe the fault codes needed to be cleared first. The check engine light cleared when is replaced a shorting spark plug boot. I currently have no alarms on the dash. My DME is a 1.3 according to the Bentley manual.
    Richmond, Virginia
    '88 735i, '06 RSX
    I highly recommend picking up a $10-13 oil and service reset tool on eBay and not mess with jumpers.
    Jul 2012
    South Yarmouth MA
    11/87 735i & 735il P/C
    Quote Originally Posted by billleget View Post
    my 735i is 11/87 and we do not get the luxury of stomp testing, unfortunately
    I also could never get the oil/service reset to work by jumping the pins. Not sure why - but glad i'm not alone. I also have an SRS light on after foolishly disconnecting the steering wheel without unhooking the battery. Can't get that to go away even with a professional laptop with BMW software - frustrating.
    Quote Originally Posted by youngbimmer View Post
    Would you mind linking one?
    Richmond, Virginia
    '88 735i, '06 RSX
    This is the one I use:
    REMOVED
    EDIT
    I just tried on my 12/87 735 and it did NOT give me 5 green bars upon pressing service interval reset. I have removed the link I previously posted.
    Feb 2018
    Belmont, NC
    1988 BMW 735i
    For clarification, what I'm trying to accomplish is to get the first of the five green oil service interval lights to energize. I only have four green lights lit now. The 735i has 10,600 original miles and was in storage for 25 years. I've changed the oil/filter and was trying to get all five green lights to light as a result of the oil reset being reset. The problem could be that the first green light bulb/led is burned out and I thought the oil reset wasn't resetting when it actually was.
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    Let's see this 735i with 10k original miles!
    90,700 miles 1992 BMW 735iL Azure Blue Metallic with Silver Grey leather interior ‣My car ‣My YouTube channel
    Nov 2007
    SF, bay area
    94 740, 74 wagoneer
    Quote Originally Posted by Cactuar View Post
    Please.... pict...
    As for stomp test our 94 740 stomp test does not work... and the reset by shorting did not do squat either...
    Jan 2005
    Japan
    reset: check pin 19, Peake has some info on page 39 troubleshooting / common problems http://www.peakeresearch.com/manuals...201.0%20NA.pdf
    observe than pin 19 of your diagnostic connector is not recessed, a number of models in the early 1990s has pin 19 improperly installed
    Aug 2008
    Earth
    8/88 750iL
    Wow, yes, seconding this -- hell yes, lets see some pictures please. What's the story here? Single owner car?
  1. Oil change service reset video
    By Johnjjo in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 11-22-2014, 11:25 AM
  2. 1988 735i 5Speed Oil Pan
    By philperry in forum 1988 - 1994 (E32)
    Last Post: 04-24-2013, 07:32 PM
  3. 1988 735i oil filter location?
    By YaoiWiccan in forum 1988 - 1994 (E32)
    Last Post: 09-29-2011, 05:24 AM
  4. Oil change service reset
    By kdub850ci in forum 8 Series (E31)
    Last Post: 05-01-2011, 05:14 AM
  5. Oil and Service reset tool
    By cos M3/4 in forum BMW Parts For Sale
    Last Post: 05-27-2003, 04:03 PM
