Results 1 to 9 of 9
Thread: y am I getting anxious?...vcg m52tu
    Mar 2003
    somers,ny
    life ( for me)for a few yrs has been nuts.........now corona..........
    I need a new vcg on my 240k orig set up m52TU 2.8 coupe....its leaking bad
    my anxiety is that after eyeballing it yesterday I dont see how I can get my hands to the bolts back by the firewall........ I could maybe get it off...but I fear I wont b able to get it re installed?
    how can I partially detach the black plastic harness cover that spans that area from pass to driver side?.... how can I detach it to get more hand room?
    Apr 2020
    Colorado
    E90 335xi
    Hey brother. I understand the anxiety, and while I haven't done this myself... It looks like you can open up the casing for the wire harness and then pull that casing off of the firewall. It should be pretty easy... I've done valve covers on much harder cars, I'm sure you can do it.
    Sent from my Pixel 4 XL using Tapatalk
    1999 Z3 Coupe MT (just purchased)
    2008 335xi AT (for sale
    Mar 2003
    somers,ny
    I should look one more time...but w/ my glasses on....lol
    thnx
    ive searched online for 20 mins so far....nada...re removing or loosening the harness cover......its just seems in the way..and Im worried about re installing the wires that run around rear pass side of the head under the v cover.
    i really want to do this myself....
    I usually stick a long extension through the wires (carefully) to get those. Think for the other one just a deep 10mm on a ratchet
    The wiring harness box is only attached with two phillips from the top. Easy to move if its in the way. Brackets are also very soft, it can just be moved (pushed/bent) if you need a little mote clearance.
    Dont overthink this. Its the simplest job you can do. Dont forget to replace the rubber donuts under the washers.
    Mar 2003
    somers,ny
    ok G...thnx
    lower lt frt fender.....arctic?
    Jan 2020
    Dallas, TX
    1999 Z3 Coupe
    I just finished replacing my entire cooling system and crankcase ventilation system which entailed removing the intake manifold.
    You are correct that the back of the engine space is tight between the engine and the firewall. I too chose to disconnect the bracket and plastic channel that holds the wiring harness. The top of it came of steadily and relatively easy by using a small flat screwdriver to gently open the plastic clips around the front and side edges of the channel. The top piece separates from the rest of the channel.
    Then there are two nuts, one on each side of the channel, underneath it that hold it to the firewall. I used an extension on my 1/4 inch ratchet to remove these nuts. There are studs that are attached to the firewall that these nuts are attached to.
    Once I removed the two nuts, I was able to move the channel and harness up and out of the way. It only took 15-20 minutes and is pretty easy.
    You can do it.
    Mar 2003
    somers,ny
    Ok. Did it. After life and anxiety held me back for over almost 2 yrs
    Loosening and removing harness box did help for area back by firewall
    Amazed how ez the nuts/donuts released. a fter 20 yrs and 245 k miles
    The donuts looked fresh and the vcg was not ! brittle. All original
    Strange how only one donut gave me grief upon install. It kept going askew and oozing out upon tightening
    I’ll just watch it
    Oh !
    I lost 2 coil pack bolts
    Any1 have some spares?????
    Thnx to all for the support
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Quote Originally Posted by jrkoupe View Post
    I'd certainly find those before I fired the motor! Sounds like you need a magnetic parts tray.
    Nathan in Denver
    Mar 2003
    somers,ny
    You are no help. Lol
    They did not end up on floor. I think they r in some recess in chassis Car has been started and run 10 mins
  1. opinions..risks...vcg leak on ex mani......99 m52tu
    By jrkoupe in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-26-2019, 07:45 PM
  2. 1999 2.8 M52TU SWAP FOR A 1997 2.8 M52 w/LOWER MILES?
    By Z3Don in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-27-2004, 09:44 AM
  3. Wtb: 2.8l M52tu Throttlebody
    By Z3Don in forum BMW Parts Wanted
    Last Post: 11-08-2003, 11:47 PM
  4. M52TU rev. hang TSB?
    By scotty_passat in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-30-2003, 11:34 AM
  5. vcg replacement: anyone do this?
    By virtualj in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-07-2003, 05:03 AM
