Results 1 to 4 of 4
Thread: SES code p0174-p0171
    May 2020
    San Diego, California
    2004 bmw 325i
    hey everyone,
    So the other day I took a log trip from San Diego to LA, I checked my dipstick just making sure all the levels were right, coolant etc. And an SES light came on about an hour after. I realized later that my dipstick was not fully in the holster by about half an inch. Anyways, took it to autozone and got the code ran. P0171-P0174. Called my mechanic he said the car should be fine, but to bring it back as soon as possible because it could be a variety of hoses, intake manifold gasket and who knows what else. The cars mpg sensor is all over the place, and of course, the idle is a little off, not anything like hunting or way sudden surges, just off by about 1-300 rpm it'll fluctuate, and this is seldomly. And when I lift off the gas, sometimes the RPM's wont drop all the way. It seems like it will be a vaccum leak of some sort, but obviously can't wait to take it to a professional to get it checked out. I have done research on the codes and all of them sound pretty common and hopefully should be an easy fix. The one thing I did notice tonight though;this is about 2 days of the codes being left on since I was not able to get back to San Diego right away and had to drive home, that today the engine bay felt very hot after shut down and a "hot smell" briefly came through the cabin. Not anything like oil, or sweet like radiator fluid, just a hot smell. Opened the hood and the engine bay was very hot. I know engine bays are hot, but this was like the devil's hooves. Anyways, proceeded to let the car cool down and checked the coolant level bopper, that was all good. And checked my dipstick to make sure it wouldn't possibly be an internal motor leak or valve cover gasket. And that was all good as well. Is this normal for this to happen with this code? Other than that- that car has been running fine and shifts fine, rpm's surges don't happen, the temp gauge is dead center. I'm hoping it's not a cat converter.
    Mar 2019
    ATLANTA GA
    456 X3s
    Kalifmora: glad to see your getting things sorted. I don't think your in dire straits
    Sounds like your mechanic is familiar with this and he should be, these codes are very common! Btw at any chance do you have installed the "performance" air filter?
    Keep us posted with your solution.
    Sent from my SM-J727T using Tapatalk
    May 2020
    2004 bmw 325i
    Thank you! and yeah, my mechanic says so as well, and no there's no performance air intake at all, car is 100% bone stock
    Jan 2016
    Ca
    2001 525it
    Ya it can be pretty dam hot in the engine bay, their lean faults
  1. 2004 BMW 325i e46 OBD Codes P0174 & P0171
    By dudley237 in forum 1999 - 2006 (E46)
    Last Post: 11-14-2014, 01:05 PM
  2. e46 codes P0174 P0171
    By Tigerweld in forum 1999 - 2006 (E46)
    Last Post: 10-06-2014, 02:25 PM
  3. SES code P0174
    By neun in forum 1996 - 2003 (E39)
    Last Post: 09-11-2014, 12:06 PM
  4. Throwing codes p0174 p0171
    By arice in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-08-2014, 12:57 PM
  5. BMW codes P0174 & P0171 - broken vacuum hose
    By newnovice in forum 1999 - 2006 (E46)
    Last Post: 07-25-2013, 02:29 PM
