backstory: we've been a 1 car family for a long time. the wife learned to drive stick, and that's given me license to get very fun cars as dailies. now that we have a kid though, the inevitable transition to an SUV is looming, and so I bought a fun weekend car (the roadie) to not feel bad about eventually getting rid of the F80. everything was great, until i drove them back to back, and it's just tough to overcome the ~150hp/200ft-lb difference between them, regardless of weight.
... sooo where do i start learning about the turbo route ?
i'm looking for a project anyway (or i wouldn't have bought a 20 y/o car), and i don't need dd reliability, nor will i track it. i just want to feel more when i mash the pedal. it's either a turbo, or an S62 conversion
S62 conversion gets my vote. Youd still be down on power though compared to an F80
I know a few guys who have done M62/S62 swaps into Z3s. Few ways to do it. Since your car is an S54 it would need minimal wiring changes. Hardest part seems to be relocating the ABS module...
Turboing an S54 can be an expensive proposition... If you really want to go turbo, its probably easier and cheaper to reach a given power goal by starting with an S52.
PRICE CUT on ALL FABRICS
a bit down on hp is ok, esp if i get a v8 out of it.
i did start with looking at the s62 conversions, but haven't been able to find too much (other than it's been done, and you need to do a dry sump to make it fit). i'll look into it further.
you think that it's a cheaper route than turbo? i guess i'd be able to sell the motor to offset a decent chunk of the cost..
I’d say go with a Hyde Motor Works Sc Kit. I’m going to be adding that to my s52 in a few weeks.
https://hydemotorworks.com/shop/prod...rcharger-kits/
― George Orwell
You do not need a dry sump to make an S62 fit. There are conversion kits which include custom oil pans which fit over the e36/z3 subframe. This is the easiest solution, the kits also come with engine mount arms
Another option is using an N62 oil pan and pump. The N62 is rear sump like the e36/z3 and the oil pan fits neatly over our stock subframe. It requires some modification to fit on the S62/M62, the biggest of which is modifying the length of the oil pump shaft. But this gives a nice lightweight aluminum oil pan, whereas the custom conversion kit uses a heavy steel piece
Whether its cheaper than a turbo is hard to say, but probably not.
interesting. https://cybul.eu/shop/bmw-e36-and-z3...ap-kit-copy-2/ (first google hit, i'll do more research)..
quick ebay search for an s62 motor + trans pulled up a $5K BIN. so it's probably ~10K all in (i'm assuming engine, a conversion kit of some sort, the RF kit, + "other"), less whatever I could get for the motor.
hmmmm
Isn't a MaxPSI S54 turbo roughly $10K too?
"So we've come to the conclusion that BMW just has parts laying around they decide to throw on cars for no reason."
Interest on a Very Budget Supercharger Build??
As an S62 owner (e39 M5), while the M5 is a blast and the torque is addicting, that engine has its fair share of issues and maintenance. Most notably, my car (9/99 build date) drinks a liter of 10W-6 about every 1500 miles, has the carbon build up issue, and is tons of fun if your hobby is diagnosing check engine lights. I guess that said, it's served me pretty well for 188k miles so far. The S52 and S54 are both so much easier to live with. I think a wise BMW Mechanic once told me, never buy a BMW that doesn't have an I6.
Well mostly all this time we have been exposed to only centrifugal blowers, which are in layman terms a turbo being driven a set of gears that are turned by a belt more or less.
A Roots or Twinscrew Supercharger is a different beast altogether. Torque and low down power is there from the get go, no spooling no nothing. With the right blower you will get boost at the low end.
We actually have a car in the Chicago area using a small blower, why dont you got for a ride sometime. That and it seems GG///M3 is doing a build soon, see how his goes before you shell out any money on any supercharger or turbo.
To me the S62 has always been one of the most reliable M engines. Rod bearings and occasionally VANOS issues are the biggest things on those engines and those arent that big of a deal. The M5 I owned needed nothing outside of normal maintenance when I owned it. Just oil changes in fact. Eventually I started throwing money at it preventatively. Its not an S85
I have been down the supercharger route, but there is no comparison to the modern turbos. My new turbo setup has more torque/power everywhere and definitely more smiles. There is no perceptible turbo lag, and I can turn the boost down if I let my wife drive the car.
1999 M Coupe
If you're not married to the idea of a bmw engine, there are plenty of proven ways to get 400hp out of a bone stock ls2. Having driven a supercharged s52 z3, s54 and ls2...I can tell you that there is no comparison to 400hp and tq in that car.
if i were to do an engine swap, i think i'd want it to be the s62 (realizing that an ls2 swap is probably cheaper).
the idea of a blower is somewhat tempting given the apparent simplicity and knowledge base, but where's the fun in doing what so many others have done?!
seriously though, i'll take a look at twinscrews too.
