Results 1 to 10 of 10
Thread: Turbo s52
    May 2020
    New Jersey
    BMW m3
    Turbo s52
    New to the forums. Have an s52 engine and plan to turbo it. Goal is 600-650hp. Planning on using a 6266 as my turbo but wanted to build the bottom end first. I’ve heard a JE/eagle setup was the best. Can anyone tell me what specific piston set is the best, I am honestly just confused with all the options. If anyone can steer me in The right direction I’ll appreciate it.
    Dallas, TX
    98' M3/4/6T
    The first thing to consider is what fuel type you will be using. Are you going to be dedicated pump gas if so, what octane? Do you have access to pump E85 nearby?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I don’t know that JE/Eagle is any better than Wiseco/Eagle or any better than Mahle/K1. I looked at prices and JE/K1 were about the cheapest at that time. If you are using an engine builder, I would ask the builder what he likes working with because you may get a better result than if you bring in a box of parts that your friends on the Internet recommended.
    It’s great that the new people start at 600 rwhp now. When I joined the forum, 400 rwhp was still a lot of power.
    Mar 2013
    Upstate NY
    M3
    Haha yeah for real. If you're not tripling the factory horsepower then are you even trying anymore. Hehehe
    Apr 2006
    Minnesota eh?
    86 325es
    K1, Molnar, and eagle rods are all fine, as are pistons From wiseco, CP, JE, Diamond, Wossner, and Ross. Honestly you really can't go wrong so just pick one and call them and tell them what you want.
    May 2020
    New Jersey
    BMW m3
    I have access to E85 but don’t want to run it 24/7. I should be running 93 most of the time.
    hahaha I guess that’s the new normal lol
    Biggest problem I was having was finding the right pistons that would fit the cylinder. Blocks at a machine shop right now.
    I see what your saying. If I was already going to build the block why cheap out? And I’m building this by self with my cousin in our garage for a summer project.
    Apr 2006
    Minnesota eh?
    86 325es
    You just have to call whatever piston manufacturer you like and tell them what you want and they will make it.
    Jun 2005
    New England
    Or order off the shelf and the machine shop will bore the block to fit. I ordered the 297170 from a JE reseller.
    https://www.jepistons.com/applicatio...-e36-22mm-pin/
    If your bores are oval you would need the next over bore size. If you are running E85 full time you might want 11:1 CR instead of 9.0.
    I assume Wiseco and Mahle have some standard specs as well.
    Jun 2001
    hell
    turbo e36 m3/ stock s50/e30 m3
    96 M3, GT4094R, Arrow Rods, CP Pistons, Elring HG, cutring 87mm, 10 mm ARP studs,MS3pro, EMC Intercooler, n54 6 speed with Motiv twin disk, ZT-2 wideband, Zionsville Radiator, X-brace, H&R springs with bilstien shocks, QTP electronic cutout, Line Locks, stock exhaust 455rwtq, 453rwhp at 14 psi 91 octane.......684rwtq, 681rwhp at 24 psi running flex fuel E60 at time of dyno tune.
    FL
    are slow.
    -Dr. Seuss
  1. FS: Built 8.5:1 C/R Turbo S52 Engine in DFW
    By BMuu in forum Race Cars & Track Parts
    Last Post: 08-18-2012, 02:30 PM
  2. ICS twin turbo S52 M coupe 600rwhp
    By CaliAgents in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-28-2008, 04:02 PM
  3. E30M3 with turbo S52 project car
    By techno550 in forum Forced Induction
    Last Post: 04-16-2008, 10:45 PM
  4. Turbo s52 - ti Dyno @ 12-13 psi
    By rennteknik in forum Forced Induction
    Last Post: 03-14-2007, 02:09 PM
  5. WHAT ARE YOUR EGTs?............FOR TURBO S52
    By RJ's325ITS in forum Forced Induction
    Last Post: 05-16-2006, 04:54 PM
