My 1988 BMW 528 Super Eta is finished in Alpine white over Black recaro seats
2.7-liter M20 inline-six with Ireland Engineering cam OBX headers, Standalone Megasquirt ECU and individual throttle body
Work under my ownership included the installation of a 5-speed manual transmission, replacement dash, recovered power front sport and rear seats, and much more as listed extensively below. This E28 shows 165k miles with a working odometer
The car was originally finished in Alpine White and the VIN Check report shows no accident. All vin tags are present, Hood, doors, The body is straight and rust free.
Later BBS RC 90 17″ Style 5 wheels and a suspension overhaul completed by me included Ground Controls coilover paired with new Bilstein B8 shocks and struts.
Black leather seats the factory power sport seats, rear bench, and door panel inserts. The front seats were recently recovered with german leather by the me. Black door card tops and a small rips in the headliner.
There is No rust in the doors, rockers, shock/strut mounts, pinch welds, wheel wells or under the car. All bolts came off easy.. nice working on a rust free southern car.
Power is provided by a stock 2.7-liter M20 inline-six. Shortly after I purchased this car, I installed a 5-speed getrag 260/6 manual gearbox in place of the original automatic. A 3.25:1 ratio limited-slip differential was installed by me.
A handful of parts receiepts will be included.Engine:
Ireland engineering 284° cam
RHD individual throttle body
Megasquirt Standalone computer
-Innovate wide band O2 sensor
-ARP Head bolts
-Cometic Reinforce head gasket
-Gates Kevlar timing belt
New OBX Stainless Steel Headers
- New Oil pan gasket (while I had the transmission out it was leaking)
- New Water Pump (Hepu)
- New Thermostat (Mahle/Behr 80deg)
- New Starter
- New Coolant Temp sensor
- New coolant hoses (upper/lower/under intake)
- New Coolant hose T fitting
- New Coolant reservoir
- BMW blue coolant (no green here)
- New Engine mounts
- Replacement Exhaust manifold with
- New Wide band O2 sensor.
- New fan clutch behr
- New belts all of them
- Oil bar bolts replaced with new crush washer and lock-tite-Resurface and refurbished head - valves adjusted- New intake rubber parts and hoses
Transmission:
- pulled out auto Transmission and replaced with 87/88 g260/6 replaced seals
replacement driveshaft,
- new trans mounts
- new shifter bushings
-New ZHP Shift knob
- center bearing, guibo, and cross member,
- new clutch disk (OE Sachs)-
-New flywheel
- New throw out bearing
- New Clutch master, hose, and slave
- 3 pedal assembly
- New rear main sealSuspension:
- New bilstein B8 front and rear shocks/struts on Ground Control Coilovers.
- New Strut bearings
- Front lower and upper arms with tie rods replaced by me (mpzeyle)
- New rear sway bar links
-New dog bones
- New diff mount
- New Rear half shafts (axles)
Brakes:
Front E28 M5 Calipers and cross drilled Rotors
Rear Rebuilt calipers with new rotors
ECS Tunning Braided brake lines front and rear
Other/interior/electrical:
- Front Sport seat leathers recovered Black
- Rear Seats replaced with german leather
- Replacement Dash 95% crack free
- M-tech I Steering wheel installed.
- Rear deck with OEM premium spekers
- New Battery
- Fuses new ceramic ones
Driver side and passenger B-pillar covers
- Radio Oem Blaupunkt radio
-Speakers OEM front/back and Rear speakers
- Gas tank vent lines replaced
- Fuel filter and soft lines replaced
- Heater fan replaced
-Euro map lights interior mirror
-Red Motorsport seat belts(will provide the original ones
- tail lights replaced
- Front and rear bumpers BMP kit with side skirts
-Euro grills with Hella H4 low beams sealed high beam
-Euro plate and bracket
70% of paint is original Front hood fenders and rear right quarter panel
Professional repainted by my ownership.
-E12 exteriror chrome handles
Wheels/tires:
Running Style 5 E39 17" wheels Shown with new Kuhmo tires.
90043544_203600040981099_6608089312707739648_n.jpg79501157_534972674014030_6244804086705684480_n.jpg89867354_228917024930034_4523791892126629888_n.jpg79785102_745185835979082_7655534331854585856_n.jpg101084491_175022490586768_6142140392507703296_n.jpg
Nice car, what is your asking price?
Still available?
