I apologize wrong title. as i have another 88 528 for sale and will be posting it on 5 series.
(cant seem to delete nor change the title)
Make an offer. serious buyers
My 1990 BMW 325i sedan is finished Brillant hot Red over beige recaro oem seats
2.5-liter M20 inline-six with OBX Stainless Steel headers Work under my ownership included the installation of a 5-speed manual transmission, replacement dash, recovered power front sport seats
Later BBS RC 326 17***8243;x 8" (5 x 112") lug conversion, wheels and a suspension overhaul completed by me included Ground Controls coilover(front only) paired with new Bilstein B8 shocks and HR spring on the rear.
There is No rust in the doors, rockers, shock/trunk, mounts, pinch welds, wheel wells or under the car.
All bolts came off easy.. nice working on a rust free southern car.
Engine:
OBX Stainless Steel Headers
- New Oil pan gasket (while I had the transmission out it was leaking)
- New Water Pump (Hepu)
- New Thermostat (Mahle/Behr 80deg)
- New Starter
- New Coolant Temp sensor
- New coolant hoses (upper/lower/under intake)
- New Coolant hose T fitting
- New Coolant reservoir
-New Coolant reservoir cap
- BMW blue coolant (no green here)
- New Engine mounts
- New O2 sensor.
- New fan clutch behr
- New belts all of them
- Oil bar bolts replaced with new crush washer and lock-tite
-Resurface and refurbished head
- Valves adjusted
- New intake rubber parts and hoses
-New air box mounts.
Exhaust :
BORLA
Transmission:
- pulled out auto Transmission and replaced with 87 g260/6 with only 80k replaced all seals
- replacement driveshaft,
- new trans mounts
- new shifter bushings
-New ZHP Shift knob
- center bearing, guibo, and cross member,
- new clutch disk (OE Sachs)-
-New flywheel
- New throw out bearing
- New Clutch master, hose, and slave
- 3 pedal assembly
- New rear main seal
Suspension:
-New CV Joints
New reinforce rear shocks mounts
- New bilstein B8 front and rear shocks/struts
- New Strut bearings
- Front lower and upper arms with tie rods replaced by me (meyle)
- New rear and front sway bar links
-New lower control arms
-New lower Control arms silicone bushings
- New dog bones
- New diff mount
- New Rear half shafts (axles)
Brakes:
Front: Red Ceramic Coated Calipers and cross drilled Rotors
Rear: Red Ceramic Coated Calipers and cross drilled rotors
ECS Tunning Braided brake lines front and rear
Other/interior/electrical:
-New Central locking system module
- Front Sport seat leathers recovered Beige
- Oem Rear Seats with euro headrests
- Replacement Dash 95% crack free
- M-tech I Steering wheel installed.
- Rear deck with OEM premium spekers
- New Battery
Headlights plastic covers
- Fuses new ceramic ones
- Driver side and passenger B-pillar covers
- Radio: Pioneer 400watts with Subwoofer and bloothooth connection
- Speakers Pioneer front/back
- Gas tank vent lines replaced
- Fuel filter and soft lines replaced
-Fuel Pump (VDO)
- A/C auxiliary fan replaced
-Euro map lights mirror
- Taillights replaced
- Front and rear bumpers cover and trims with fresh paint
-Front valance fresh paint
-Euro grills with Hella H4 low beams sealed high beam
-Euro plate and bracket
90% of paint is original
small dent in front hood left front fenders and rear trunk
Wheels/tires:
Design 42 Wheels lugs conversion kit
4" x100" to 5"x 112"
Running on BBS RC 326 17" wheels Shown with new Kuhmo tires.
Extra:
OEM compleate tool box
OEM Firts aid kit
OEM all weather mats
OEM center console with cassette tape storage
Led License plate lights
Euro Hecklebend
Rear Trunk Spoiler
I'll give you $5
Where are you located?
Sent from my SM-G973U using Tapatalk
