Results 1 to 18 of 18
Thread: S50 rough idle/start after 3.5 MAF/injector install
    Jul 2012
    Santa Barbara
    95' M3,
    S50 rough idle/start after 3.5 MAF/injector install---Injector vacuum leak? RESOLVED
    I have been collecting parts slowly to basically do Turners Stage 2 Tune. Meaning the proper chip, 24# injectors, 540i MAF, and a new AFE intake.
    Over the weekend I put in the new injectors and MAF and wanted to start it up for a brief second to see if I had any leaks with the injectors. Turned the key and it fired right away and ran pretty well, better than I was expecting it to without the proper chip. I then turned it off after checking each inlet for leaks. The following day, my friend had given me an RK tune chip, I didn't realized that it was meant for a different DME since I have a 413 silver label so I uninstalled it after attempting to start the car with it in. I had it crank but no fuel/spark. Anyways, come the next day I installed the stock chip again and wanted to start it again briefly just to be sure that all was good. It started, but ran extremely rough at idle, when I tried to hit the gas a little, it would jump up to 4k RPM and then go back down and possibly stall, or really struggle to idle for a moment then go back to the 'standard' rough idle.
    I have not done much else to it since I am still waiting on the proper tune and intake.
    Is it now running really poorly since I have made these changes and had the DME unplugged for a while thus the system lost its memory? Or is something else possibly wrong with what I have done thus far?
    Edit: I sprayed some carb cleaner around the lines as well as the injectors and the idle evened out when spraying it around a particular cylinder. How likely do these orings go bad to the point where they do not seal? I removed and refitted them back and still had the same issue.
    FL
    are slow.
    Has it rained in the last few days?
    -Dr. Seuss
    Jul 2012
    Santa Barbara
    95' M3,
    No, why?
    Dublin, OH
    '95 M3, '17 Civic Si
    That's really strange. I guess there's no chance it's a vacuum leak since it was running fine before you put in that RK chip, yeah?
    Have you gotten any ECU codes?
    -Rich-
    Jul 2012
    Santa Barbara
    95' M3,
    Quote Originally Posted by das borgen View Post
    I do not think I am having any major vacuum leak to cause all of this considering it was running fine prior to me messing with the chip in the DME.
    I did not really run the car long enough to pull any codes since it was sounding rather scary. I think collectively I ran the car for about 20-30 seconds after swapping back the OEM chip. Would having the battery disconnected for a few days allow for enough time to discharge the DME capacitors make it so their stored values are lost to the point where it would even run that poorly? Also when I removed the Stock chip again, I noticed that some of the pins were bent, they were still in their respective sockets, but who knows if that may have caused anything weird to happen too.
    Jul 2012
    Santa Barbara
    95' M3,
    UPDATE: Got my turner chip, installed it and put it all back together. It still is running very poorly, the CEL is on and the code given is 1281- DME Memory unit supply... Anyone with thoughts?
    FL
    are slow.
    Quote Originally Posted by cfletch13 View Post
    No, why?
    Early E36's have ECU compartments that can flood.
    -Dr. Seuss
    FL
    are slow.
    https://www.bimmerforums.com/forum/s...5628-DME-issue
    https://www.bimmerforums.com/forum/s...ry-unit-supply
    -Dr. Seuss
    Jul 2012
    Santa Barbara
    95' M3,
    Unfortunately none of those really seem to be similar to my issues, while they have that code thrown, it seems like they can drive. My car can barely stay alive idling let alone actually drive.
    Still hunting
    Jul 2012
    Santa Barbara
    95' M3,
    Just got out there again and sprayed some starting fluid around to see if the idle improves in case of a vacuum leak. I sprayed around 1 injector and the idle improved. I am thinking maybe it was not seated well? Does this all make sense
    Mar 2019
    Silver Spring, Maryland
    1990 325i
    if you take brake cleaner spray over the intake/injector and you have a change in idle that indicates a vacuum leak. Don forgot to check the ICV hose and make sure they're not cracked or unplugged.
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    I'll bet you that you have a bad/incorrect 3.5" MAF. Install the 3.0, and OE chip and see what happens. I'd bet you that it at least runs better.
    Jul 2012
    Santa Barbara
    95' M3,
    Quote Originally Posted by RRSperry View Post
    I swapped to new injectors and still had the same issues with idle, checked the new code on the CEL and its going with 1215. I just swapped the maf back to stock 3.0 size and am waiting a bit with the battery disconnected so I can throw in the stock chip... sighh
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Did you use a real MAF or chinese copy?
    Jul 2012
    Santa Barbara
    95' M3,
    UPDATE:
    The older injectors were not even an issue. The whole reason why the idle fluctuated when I sprayed that specific injector was because somehow the top hose from ICV to manifold got disconnected? Since the injector was pretty close to the hose, it sucked it up and made me think it was that injector causing all the issues. I swapped back to the correct tune, intake boot, MAF and all runs perfectly. I went for a long drive and love the new feel of everything. Thanks for the suggestions you guys!
    RRSperry's Avatar
    Mar 2002
    Eldersburg, Md
    It's always the last place you look... Have fun...
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    Well yeah, silly to keep on looking after you’ve found it!
    Neil
    Dublin, OH
    Quote Originally Posted by NeilM View Post
    Neil
    yeah, you'd have to be an idiot to keep looking once you've solved a problem.
    Glad it was a vacuum leak like I thought, OP!
    -Rich-
  1. S50 rough Idle and 1281 Code after chip install.
    By BMW2NR in forum 1992 - 1999 M3 (E36)
    Last Post: 04-24-2012, 05:32 PM
  2. rough idle immeadiately after starting
    By B4rb3r in forum 1992 - 1999 M3 (E36)
    Last Post: 11-16-2008, 03:11 AM
  3. e30 rough idle/start problem
    By xsproutx in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-05-2007, 05:05 PM
  4. rough idle problem after working on manifold e36
    By renegadevii in forum 1991 - 1999 (E36)
    Last Post: 09-12-2007, 10:01 PM
  5. CEL: Very Rough Cold Start after driving in rain...
    By redrocket328 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-02-2007, 10:06 PM
