Results 1 to 14 of 14
Thread: The problem that keeps on giving - Coolant leak
    May 2020
    NZ
    1995 318is
    Afternoon Team,
    1995 BMW 318is.
    It all started as what appeared to be a simple problem, old starter motor had smoked up good and died.
    Unfortunately I had no way of getting the unit out from underneath as the started motor mounting hole closest to the block had a nut as well as the E12 bolt so decided to tackle the problem from up top.
    It was smooth sailing for a short bit until the mighty squid got in the way and it was time to take the alternator out which had been there since factory so the small rectifier terminal decided to snap.
    Small job turns into new alternator as well. Should have probably done the knock sensors cause they were falling apart but decided against it.
    Many swear words later, all is back on time to start it and goes first pop huurrayy what a painfull victory.
    Take it for a short drive up and down the drive park it up and decided to check under the bonnet for old times sake.
    BMW had now decided to start spewing coolant somewhere towards the back of the block and it sounded like it was spraying like a small "hizzzz"
    I need some advice as to what could be leaking? it did seem to be dripping/spraying directly onto the starter motor, there was no coolant towards the from of the block and and only really started to do it when the car got up to temp.
    If i do recall correctly one of the lines I had to undo to get to the starter from the top had water in it.
    Does anyone have a diagram?
    I may recall one of the lines that had to be undone to get to the starter had water in it do we think this may be what has caused this?
    Not looking forward to possibly having to take the whole intake out again unless there is no way around it?
    Any help would be amazing.
    Thanks!
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Wow... sounds like a headache! I don't have the answer but perhaps the people in this discussion area can help.
    88M3 AW 43k miles Project FS
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    Could be any coolant line. There are many. Your going to have to find the wet yourself.
    Jun 2010
    NY
    1997 328i
    Sounds like time to replace all the coolant lines.
    May 2020
    NZ
    1995 318is
    Update had another look today one of the two lines that go onto the little wedge thing in between the manifolds decided to go so sorted it.
    However the problem that keeps on giving has now moved to the radiator fan, car gets up to temperature and the fan does not kick in, ideas?
    May 2015
    U S A
    yay
    Check if it is getting voltage.
    CARS
    02.92 325is / 06.72 2002 / 02.91 XJ / 08.04 R53 JCW
    Nov 2013
    Oneida, NY
    Fan doesnt kick on when it gets to ot. It kicks on when it gets a bit above ot.. If its starting to overheat and the fan doesn't kick on, put the AC on in the car... If the fan comes on when you click the ac on, the fault is in the temp switch, wireing, or low speed fan relay. (Or fuse if you havent checked there first)
    May 2020
    NZ
    1995 318is
    Cheers heaps bro will have a look at it tomorrow!
    Apr 2020
    sea\
    1996 318is bmw
    its the heater connector hose in the back had the same problem its plastic they dont last
    Oct 2016
    Austria
    e36 323i, M3 3.2
    well if you disconnected a water hose and didn't bleed and get the air out, then you have air in there now and your cooling system will not work properly. and you must have lost some coolant when disconecting that hose the first time. did you fill up your coolant to the correct level again ?
    May 2020
    NZ
    1995 318is
    Update,
    I did not bleed the system after the coolant dropped, it honestly didnt seem like much and coolant level is sweet.
    Today after much procrastination I decided to start it up again and see what it did
    So the fan doesn't engage even when it gets to red on the temperature scale thing however if I run the aircon on it does intermittently engage and disengage by itself.
    I have noticed fuse 41 is missing which is listed as aux fan which I am guessing this might be what it comes in under? if so what amps should I put on there?
    I have a feeling if its not that then it might be the relay?
    May 2020
    NZ
    1995 318is
    Update, replaced High speed fan relay and car is still doing the same so I am leading towards its got an air bubble.
    I will bleed the coolant system tomorrow however I just noticed the bleed screw on top of the radiator is glued so unable to open, would it still bleed the system if I ran it with the radiator cap off? cheers heaps
    Feb 2016
    Central florida
    1998 M3 convertible
    Check the electrical plug for the fan at the bottom of the electric fan shroud . This was the non running fan issue on both of my cars.
    May 2020
    NZ
    1995 318is
    Cheers for the help everyone.
    Issue was air pocket...so all is good now - probably jinx myself there.
  1. Having coolant leaking problems
    By kokbelin in forum 1975 - 1983 (E21)
    Last Post: 08-19-2007, 08:35 PM
  2. Argh...coolant leaking problem.
    By sKunkman in forum 1991 - 1999 (E36)
    Last Post: 06-28-2007, 12:26 PM
  3. Lower driver side coolant leak problem
    By ashamans in forum 1996 - 2003 (E39)
    Last Post: 11-13-2006, 06:08 PM
  4. Coolant leak problem
    By evild33ds in forum 1992 - 1999 M3 (E36)
    Last Post: 06-21-2006, 06:23 AM
  5. Coolant leak problem
    By fstbmwm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-19-2002, 10:04 AM
