Results 1 to 10 of 10
Thread: Cigarette Lighter - Switched Power
    Oct 2005
    Tracy, CA
    e46 325XI, e36 M3
    Hi all- looking to convert my cigarette lighter to switch power since I always leave the phone charger in. I previously had a thread on m3F before it imploded on some recommendations by so electrical pros.
    I know I should run a relay to a switched source like the radio, but can anyone give some guidance and recommendations?
    For example, should I add another fuse somewhere? what type of relay or gauge wiring should be used.
    Port St Lucie, FL
    1998 M3/4/5
    I installed a dual USB socket in place of the cigarette lighter. Since there is constant power I then installed a small rocker switch in one of the blanks. The cigarette lighter is on a 30-amp fuse which I replaced with a 10-amp fuse. Look up how to wire a 12v switch. No relays or other fuses needed. The cigarette lighter is on its own fuse and circuit.
    Oct 2005
    Tracy, CA
    e46 325XI, e36 M3
    that's a clean looking rocker switch. where did you get it and did you simply intersect the ground (brown) or hot (red) to it?
    Port St Lucie, FL
    1998 M3/4/5
    I bought the USB and micro rocker switches from Amazon. The USB ground wire goes to ground directly. The power wire for the cigarette lighter goes to one side of the switch. The other terminal of the switch has the power wire from the switch to the USB. I used the existing ground and power wires for the cigarette lighter and added pieces to reach everything. The switch is not grounded.
    Feb 2010
    NJ
    97 Estoril M3/4/5
    This would definitely be a slower charge, but for a cleaner look you could install a wireless charger.
    https://www.youtube.com/watch?v=LO8Qir7d1Ec
    Aug 2011
    Vancouver, BC, Canada
    99 M3 Vert
    If your car came pre-wired for the carphone, you could splice into that set of wires, it's right under the centre console which makes it very convenient.
    Feb 2010
    greenwich, ct
    93'M3, Testarossa,
    My cigarette lighter socket has no power. Does anyone have a wiring diagram to trace the problem. I need this as I use the lighter for charging my phone/
    steve
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    You knew, you could take power from the glove box flashlight and wire in a 12v to USB running into a cup holder or ashtray.. but I like the dual USB...
    Port St Lucie, FL
    1998 M3/4/5
    Quote Originally Posted by RRSperry View Post
    I had intended to use the flashlight socket (since my flashlight was gone). But, even though the wiring diagram says it’s switched power, mine was hot with the ignition off.
  1. Cigarette Lighter socket, power is always remains on
    By Minimalsix in forum 1991 - 1999 (E36)
    Last Post: 05-05-2010, 12:00 AM
  2. Cigarette Lighter /DC power replacement
    By orbbb in forum 1999 - 2006 (E46)
    Last Post: 05-05-2008, 02:27 PM
  3. cigarette lighter 12v power
    By Xiphos in forum 1992 - 1999 M3 (E36)
    Last Post: 12-22-2007, 03:01 PM
  4. Cigarette lighter = no power
    By Shadow86325e in forum 1983 - 1991 (E30)
    Last Post: 10-13-2007, 06:04 PM
  5. Cigarette lighter, no power!?
    By Nillaice in forum 1991 - 1999 (E36)
    Last Post: 12-29-2004, 06:10 PM
