For Sale: Forgestar CF5 18”
sold!!
Deep Concave (full )
https://www.forgestar.com/wheels/rotary-formed-monoblock-series/cf5/
Two, 18×11 offset +23 (estimated at ~23lbs)
Two 18×12 offset +36 (estimated at ~24.5lbs)
PCD: 5x120
Hub bore: 72.56 (can use hub centric rings to go down for others including Corvette - @70.3, etc.)
All 4 ordered in Raw finish and custom powder coated in a maroon bronze like finish.
Built for widebody BMW e46 M3 and after changing kits, decided to change wheels to a square setup for track day usage so these must go. Been sitting with tires mounted and used only as rollers, never actually run for more than moving around the shop and on dyno briefly. Some of the faces have light surface flaws but just from mounting and storing. Likely all can be 100% polished out but I want to be completely upfront about the condition. Basically 100% new and straight from the factory. Comes with two forgestar center caps (carbon look). Others went missing but readily and affordably available. I’ll find some if you really need the set! Likely fit on Corvette applications as well.
Currently have a set of 295/30/18’s R888R on the fronts. Fronts got cuts from bodykit and bodywork adjustments so I wouldn’t use them for any serious use (road or track). Great rollers or casual driving, otherwise brand new, etc. Great also for a smoke show and drifting! Rears are good to go with ~99% tread, properly stored inside and in excellent shape. Tires are optional for an extra price if you want them, make an offer with everything or they can be sold separately (or I’ll keep the tires for something else). Fronts were $550 new. Make a fair offer.
CF5Deep Concave5 SPOKE STYLING
- MONOBLOCK CONSTRUCTION
- ROTARY FORMED FLOW FORMED BARREL
- LIGHTWEIGHT
- CLEARS BIG BRAKE KIT
DISCLAIMER: All Forgestar wheels are drilled to cone seat specs. Conical/tapered lug nuts will be required.
Retail on these wheels (no tires) with Custom Powder Coating is over $2200.
Asking $1,000 for a quick, cash sale, picked up in West Los Angeles. Can deliver locally for $50 (with non refundable deposit of $250 via Paypal or Venmo) within 20 miles of 90049. Tires, make offers if interested on their own.
Rear tires sold. Price dropped to $1000 for wheels with no tires!
Dropped to $999 OBO! Make a fair offer for your widebody needs!
$899 obo
Happy Father’s Day!
