Results 1 to 8 of 8
Thread: Tailgate issues 2014 328xi
    Jan 2014
    kansas city
    2001 BMW 525it
    I have needed to open my tailgate with the remote or the switch at the drivers seat for months. The button on the hatch did not work. This morning I took 2 large dogs to the dog park and when I returned home the tailgate would not open from the switch at driver or either of my 2 remotes.
    I can hear a noise as though the hatch is released. It just doesn’t open. Any ideas???
    Robin Gierer
    Jan 2014
    kansas city
    2001 BMW 525it
    Quote Originally Posted by ragierer View Post
    Robin Gierer
    I have looked at all fuses I can find, under the hood and a few in the cargo area above the battery.
    Still hoping for an idea t
    Jan 2014
    kansas city
    2001 BMW 525it
    Some information.
    I have learned.
    This car should be equipped with an emergency release handle in the floor.
    If yours is gone, focus on getting to the floor of the rear of your car. Not an easy task with the hatch closed, but you can find a way.
    Under the door in the latch area there is a tab you can pull on with a needle nose pliers to release the hatch.
    Now I will start to reassemble my car a bit and try to sort out what went wrong.
    Robin
    Jul 2004
    Houston, TX
    36 Cylinders
    We'll assume this is the wagon? Please id the car type
    The release latch can theoretically get stuck, with dirt or animal hair, so the emergency release string would help get it to release. It would have to be cleaned or maybe even replaced if it doesn't respond.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2014
    kansas city
    2001 BMW 525it
    The car is a 2014 328xi wagon.
    I have used a guitar string to restring my emergency release, now I can function day to day.
    I will lube lock tomorrow.
    It seems to me that the electronic mechanism is not working. I have been through my fuses but no joy.
    I am hoping someone has been down this path before.
    I am passed the immediate crisis but would love to be able to fix it without the dealer.
    Since the emergency release equipment was all gone, I have to believe it has happened before.
    I purchased car used with 26.000 miles, but 5 years old.
    Any ideas?
    Robin
    Jul 2004
    Houston, TX
    36 Cylinders
    You can replace the latch (if it's truly not working). It was used on multiple models, so they aren't too bad to find used even.
    It will involve pulling some trim, and then disconnecting it from the soft lock mechanism that is found on the left side, D pillar area.
    -Abel
    Jan 2015
    Philly
    '14 328xi Sport Line
    Does the wagon have the valet lockout switch in the glove box, and if so, is it set to "lock"?
    2014 328i xDrive | Black Sapphire / Black Red Dakota | Sport Line | Premium Pkg | Lighting Pkg | Cold Weather Pkg | Driver Assistance | Nav | Shift Paddles
    Jul 2004
    Houston, TX
    36 Cylinders
    Haven't seen such button.
    Also this may help if you need to replace the lock
    https://www.newtis.info/tisv2/a/en/f...locks/KRIzQLce
    -Abel
  1. new tailgate issue
    By liamthegeezer9 in forum 1996 - 2003 (E39)
    Last Post: 09-22-2013, 01:53 AM
  2. Window and Tailgate Issues
    By 03e39t in forum E39 Touring / Wagon
    Last Post: 06-24-2013, 07:41 PM
  3. 2000 528iT Touring Tailgate issue
    By Johntee540 in forum 1996 - 2003 (E39)
    Last Post: 03-16-2010, 04:15 PM
  4. Tailgate issues
    By GriffMZ3 in forum 1996 - 2003 (E39)
    Last Post: 10-12-2009, 02:16 PM
  5. Help a fellow touring owner out!! Tailgate issues!
    By sabbos1 in forum 1996 - 2003 (E39)
    Last Post: 10-05-2006, 02:16 PM
