Results 1 to 4 of 4
Thread: 1995 M3 transmission control solenoid
    May 2020
    Washington
    1995 M3
    Hey guys where can I find a transmission control solenoid for sale for a 1995 M3 automatic. My car no longer want to shift into third.
    Do any of you know what the part number would be for my transmission
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to E36 M3 forum.
    Ever cleaned and overhauled the valve body? Maybe the valve is just stuck because of the dirt in the valve body. You can also test the solenoid valves on the plug on the side of the trans with a multimeter.
    In case it is a 5HP18, here are solenoid kits https://zftranspart.mypinnaclecart.c...=product&id=41
    May 2020
    Washington
    1995 M3
    I haven't cleaned it or anything yet. I just got the car a couple days ago. I'm pretty sure its dirty and gummed up. Sometimes it just wont shift past second but yesterday when I got out of work. Second was really sluggish till about 2500 rmps then started driving fine and went right into third I brought it on a main road and she went right into third and forth with no problem. I then went home for a about an hour. Then I got back into the car to see if would still shift normal and nope back to not going back into third. Trans light is now on. Could low trans fluid also cause this problem? I'm going to see if I can get the car on a lift this weekend. I hope the trans isn't shot i didn't want to do a trans swap this quickly so I'm hoping i can save this one till I'm prepared for a manual swap
    Oct 2005
    Tracy, CA
    e46 325XI, e36 M3
    how many miles are on the car? check if the lines up into the transcooler are leaking. Mine shifted funny until I replaced the seals and did a fluid change at 115k miles. Shifts normally
  1. 1995 M3 OEM control arm right side(passenger)
    By Jdizzle318 in forum Suspensions, Springs & Shocks
    Last Post: 10-26-2010, 02:21 PM
  2. 1995 M3 Transmission Removal Problem
    By rogue27 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-07-2010, 12:24 PM
  3. WTB wanted/need E36 1995 M3 Front Control Arm (drivers Side)
    By m3beemer16 in forum BMW Parts Wanted
    Last Post: 10-08-2007, 09:07 PM
  4. 1995 m3 climate control help!
    By Rated///M in forum 1992 - 1999 M3 (E36)
    Last Post: 12-11-2006, 07:43 AM
  5. FS: 1995 M3 transmission.
    By ATC2B in forum BMW Parts For Sale
    Last Post: 06-24-2003, 10:53 AM
