I have a brand new set of DINAN Wheels. These are original DINAN Wheels, not replicas. These wheels used to cost $2299 - $2500 per set. They are no longer available from DINAN. These are NOT staggered wheels, they are all the same size.
They are brand new in boxes. These wheels may work on different models, depending on the hub size and offset. Please do your research for fitment.
These particular wheels will fit BMW F30 (3-Series) models from 2011 - 2019. They were recently installed on a 2016 BMW 328i that is lowered on DINAN Springs / Suspension. They are a direct fit and bolt right on. Car in the picture is fitted with 245/30Z/20 Size tires on all four corners. You might be able to larger on the rear tires.
Here is some information from DINAN:
Dinan has utilized its extensive knowledge of BMW specifications to produce premier cast aluminum wheels. Dinan wheels are well regarded within the industry as some of the most aggressively wide based options available. We do this to provide the car superior traction and versatility under a myriad of driving conditions. In addition to affording the car the ability to attain and hold peak performance ratings as required by Dinan's lofty standards the Dinan branded wheels deliver a unique design that augments the refined sophistication inherent in all BMW vehicles.
Dinan Wheel Highlights:
• Lightweight Aluminum One Piece Cast Wheels
• High performance aluminum for high strength-to-weight ratio
• OE TPMS and lug hardware compatible for ease of installation
• Utilizes BMW alignment system for easy fitting and alignment
• TUV, JWL, and DOT approved
• Weight optimized by FEA analysis
• DINAN center cap included
SPECIFICATIONS:
Color: Black
Offset: 44mm
Hub: 72.56
Bolt Pattern: 5 x 120
Weight: 27 lbs
Suggested Tire Size: 245/30/20 (For F30 3 Series BMW)
Worth 3 DINAN Points.
Please send a note if you're interested or have further questions. Pick up is preferred. Shipping for these wheels is about $250 CONUS via FedEx.
The Price of $850 is for the complete set of Four Wheels - Squared.
Thanks for looking.
Here's a link to the CL Ad - hopefully that helps:
https://sfbay.craigslist.org/eby/wto/d/oakland-bmw-dinan-20-wheels-for-f30/7127681392.html
I live in the Bay and I'm interested. I'm trying to figure out if I can get them to fit.
'91 850i 6sp CB42360
'00 528iA sold
'01 740iA Msport sold
'01 540iA sold
'03 540iA M-sport II with e46 m3 SMG style steering wheel with working paddle shifters, ISC N1 coilover front, Bilstein B8/Eibach sport rear, 19" Avant Garde Anthracite M359, Hella euro spec headlights, M5 aftermarket (Umnitza) foldable mirrors (painted body color), M60 IM (custom painted body color 354), powder coated valve covers (@Finish Logic; Concord,CA), Dynavin N7, Bavsound speakers, Cerwin-Vega sub (in spare wheel hub), soundproofed doors, trunk, under rear seat, wheel wells
'00 528iA sold
'01 540iA sold
Not even with hub adapting spacers?
'00 528iA sold
'01 540iA sold
