Results 1 to 7 of 7
Thread: E24 shocker removal from strut
    Nov 2017
    Uk
    E38 728i e38 744 E90 3.0
    I have removed the struts from my low mileage 635 Highline 1989. Can anyone tell me what special tool is needed to remove the threaded locking ring that holds the shocker in the strut.
    Bilstein tell me it's a BMW special tool
    The ring is circular and has 4 holes in it 6 mm dia on a pcd of circa 46 mm that are at 90 degree intervals around it. No problems removing the springs.
    The tool must be pretty strong to cope with the high installation torque. It could be very strong pin spanner or wrench. There was a post on this forum but I cannot find it anymore.
    Lots of videos on YouTube, but not one for an e24 mention this. It's the Euro Highline version.
    Or must I buy new struts to go with the £1,600 worth of bits supplied by BMW
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I will move that to the E24 forum
    West Nyack, New York
    86 635csi 98 740i 96 MB
    North Carolina
    '86 M635/'10 Clubman
    The second link (sierra) is what I used - I just saw it in my garage yesterday. If you were in the US, I'd send/loan it to you. IIRC Bilstein sent it to me for free.
    Do you have a spring compressor?
    I'll try to post pix of what I'm talking about tomorrow
    Aug 2011
    Ireland
    M3
    The Bilstein tool is no use for the type of insert described. The description is for the likes of Sachs/Boge. To remove what you have you can make a tool or if you do not need to reuse the locking ring then a hammer and a punch can be used to undo it. Or a large stilson wrench. If there is a lot of corrosion on the threads they can be difficult to remove so lots of penetrating oil.
    Boston, Ma
    86 635,72 E3, 88M6,73 E9
    I use a plumbers wrench, thin enough to fit between the turns of the spring. Key is to loosen before you remove the strut housing.
    Rob E3
    North Central Florida
    88m5,2015 Silverado
    Back in the day, I've used a hammer and a large chisel
  1. E24 Front and Rear Strut Bar
    By 640CSi in forum 1976 - 1989 (E24)
    Last Post: 01-15-2007, 03:35 PM
  2. removing front strut bar...
    By bugkiller in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-04-2004, 05:37 PM
  3. Help: Can't remove front strut from control arm
    By cgrizzly888 in forum 1991 - 1999 (E36)
    Last Post: 01-17-2004, 07:30 PM
  4. Need to remove butt-strut before installing exhaust?
    By lllM_POWER_1688 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-02-2004, 06:35 PM
  5. Help: removing front struts on an E30 325i
    By EuroKRN in forum 1983 - 1991 (E30)
    Last Post: 04-26-2002, 08:52 PM
