Results 1 to 13 of 13
Thread: Rear Subframe cleaning
    Mar 2014
    Virginia
    02 540ia and 01 540iaT
    I dropped the rear sub-frame to refresh the suspension pieces, should I done this from the start. With 180k a lot of the bolts and e-brake cables were fighting.
    What is the best way to clean the aluminum sub-frame? I tried gunk and a brush, that combination did not work very efficient. Maybe a pressure washer or oven cleaner? What works best, I do not want to install the new suspension with the dirty sub-frame.
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Kerosene cleans everything.
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    Yes, it does, but that does not look so dirty. There is surface oxidation, but I'd leave it alone. are you looking to take it apart further? good time to do bushings.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Multiple commercial aluminum cleaners on the market any will work. Looking for shiny? Try aluminum polish... Best: A power washer after using a petroleum product like Snotty recommended that will remove all the shipping grease (Now long dried and hard).
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Mar 2014
    Virginia
    Going to slide the sub-frame out from the car and full rebuild. Replacing the rear ball joints, wheel bearings(bad), air shocks(slow leak), new Koni shocks, sway bar bushing/links, the three differential bushing and the 4 large sub-frame bushings. With the sub-frame out, I hope to do the sub-frame bushings without the special factory tool.
    Plus the brake hoses and rebuild the calipers. The wheel bearing took a lot of time to remove, the 4 torx bolts were really frozen on. Should have started by dropping the sub-frame but the emergency brakes would not come off.
    Need to clean the sub-frame and then paint with aluminum colored paint. Polishing would be more work that I want. Gunk is like 90% kerosene and did not touch the grim on this stuff. I used a brass wire brush for the aluminum part that holds the wheel bearing. Hoping to find a faster solution.
    Nov 2016
    NY
    I can see you getting the old subframe bushings out without the tool, but you should use the correct tool to get the new ones in and seated correctly.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    A wire brush on a drill will provide a nice shiny surface in a few mins. I hand polished part of mine on the M5 show car, looks great but to see it you have to face plant in the grass.
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Mar 2014
    Virginia
    78C9BC2F-4A86-4FD9-968D-FFA8EC16CB20.jpgMake sure to add the brake dust shield before bolting the bearings on.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    ^ Me like pretty.....
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Oct 2016
    Atlanta
    2001 540iT
    +1 using the tool to replace bushings. Any fool can melt out the old ones
    Sent from my SM-G970U using Tapatalk
    Mar 2014
    Virginia
    I replaced the subframe bushing using a 2 jaw puller with a slide hammer screw and a harbor freight wheel bearing kit for the press pieces and install cups. Also three hose clamps with a ball joint press to install the diff bushing that needed to be compressed for installation.
    Mar 2014
    Virginia
    This took a lot more time that I expected. It is now bolted in and have to install the e brakes, rotors and hook up the air bags.
    Sonoma Whine Country
    E12, E12, E36, E39
    Quote Originally Posted by speedracer M View Post
    If there's such a thing as a sexy subframe, that's it.
    98 328is
    02 525ita
    80 528i
    81 528ia
    and decades of owning and driving BMWs
  1. E36 M3 rear subframe (reinforced, cleaned, painted) & control arms
    By gpeterson in forum Suspensions, Springs & Shocks
    Last Post: 03-27-2013, 12:31 PM
  2. E36 E36 M3 Rear Subframe Ultra-Clean!
    By crazycasey in forum Suspensions, Springs & Shocks
    Last Post: 05-20-2012, 08:59 PM
  3. Replies: 7
    Last Post: 12-01-2011, 06:31 PM
  4. Those with rear subframe problems read this...
    By dc516 in forum 1991 - 1999 (E36)
    Last Post: 05-11-2007, 03:14 AM
  5. Question about rear subframe failure
    By Jeff P in forum 1992 - 1999 M3 (E36)
    Last Post: 04-11-2001, 02:26 PM
