2004 E46 M3 ~146,650 Miles SOLD!!!
Car has spun rod bearing. Currently running but will need new motor. Asking $5,500 obo.
6 Speed SMG
JET Black exterior
Cinnamon interior
Clean title in hand
2 keys
Purchased from BMW dealership at 65K
Many receipts and records from maintaining the car at proffessional local indy shop
Inspection 1 and 2 done
Recent Maintenance:
OEM Oil line accumulator
OEM Cabin filter
OEM front control arm bushings
OEM new battery
OEM Engine & trans mounts
OEM transmission, brake and diff fluid changed at at 135K
OEM coils and spark plugs at 135K
OEM alternator
Saleri Water Pump at 130K
OEM Clutch at 120K
OEM Rear diff bushing and guibo
Vanos done at 140k
Stop Tech new rotors and street/track pads 90%
Stainless steel front brake lines
OEM New Headlight lenses
Amber corners
Fresh Paint correction
Re-painted rear bumper. Front could use a respray but with miles the hood and fenders would need to
Interior:
Aluminum M sport pedals
Dynavin V2 Etertainment/Nav Unit
OEM clothing pieces on pillars
Suspension:
ST coilovers installed at 130K
Solid Subframe bushings
20mm spacers front
15mm spacers rear
Michelin Pilot Supersport tires 80% rear and 40% fronts
Mods:
AFE Intake
M3AN ONE ceramic coated catless headers
Rogue Engineering mid section resonators
Evolve custom software tune set to 8200RPM limit
Planned to put in a new motor but due to COVID-19 layoff, plans has changed. Car is located in the suburbs of Washington DC
Bump
Sending you a PM
Bump
Bump
Bump
Bump
Bump
Bump
Bump
Hi, I'm very interested in your m3 for sale. If you wouldn't mine please texting or calling me at 716-7two5-5366
Thank you
