Results 1 to 9 of 9
Thread: WTB E36 M3 rear halfshafts
    Feb 2019
    Rocklin, CA
    1997 BMW 328is
    Swapped our 318 M42 motor out for a 328i motor and an M3 differential. Now we need the halfshafts. Will consider just about any condition. Based in the Sacramento area.
    Thank you!
    David
    Oct 2003
    Seattle
    99 M3
    The 325 rear wheel bearing p/n 33411130617 is a 42X75X37 bearing.
    The M3 rear wheel bearing p/n 33411090505 is a 45X85,05X41 bearing.
    The M3 has fundamentally different set of rear trailing arms and half shafts, as well as brake assemblies.
    Use your 328 differential output flanges in the M3 differential. Use your 328 halfshafts and control arms.
    Research part numbers from various E36 models in www.realoem.com.
    Feb 2019
    Rocklin, CA
    1997 BMW 328is
    I would love to use 328 half shafts but the M3 output flanges are much larger. If we use the M3 shafts, I thought we would probably have to update the hubs too. Admittedly, I have not worked through all the ramifications yet.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by bluptgm3 View Post
    Use your output flanges in the M3 differential. Perhaps use 328 half shafts.
    Oct 2003
    Seattle
    99 M3
    Use your 328 differential output flanges in the M3 differential. Perhaps use 328 half shafts.
    Feb 2016
    Rogers AR
    1995 BMW M3
    Quote Originally Posted by MXDave813S View Post
    You can use the 325/328 output flanges with the 325/328 axles. The output flanges interchange
    Feb 2019
    Rocklin, CA
    1997 BMW 328is
    Ah I get it now. If I wanted to use the M3 axles, would the M3 hubs and bearings work in my 328 trailing arms? I have a set of M3 Axles and planning to change the lower wish bone to adjustables so I should have the clearance. Or, if the output flanges need to be changed to the 328 units, then that is what I will do. Thank you for all the advise!
    Apr 2015
    Tennessee
    1998 BMW 328i
    No. You must use M3 arms to run M3 bearings, etc.
    Sent from my SM-G975U using Tapatalk
    Feb 2019
    Rocklin, CA
    1997 BMW 328is
    Thank you all so much for the expertise!
  1. E36 WTB E36 M3 Rear Trailing Arms, Differential, Halfshafts
    By Spittman in forum BMW Parts Wanted
    Last Post: 11-22-2019, 07:52 PM
  2. E36 WTB E36 M3 rear bumper and trunk lid no spoiler Minnesota
    By Mallman in forum BMW Parts Wanted
    Last Post: 04-10-2010, 04:32 PM
  3. E36 WTB: e36 m3 rear bumper
    By vr4boy in forum BMW Parts Wanted
    Last Post: 04-03-2010, 06:37 AM
  4. E36 WTB e36 m3 rear strut bar for sedan
    By KGB M3 in forum BMW Parts Wanted
    Last Post: 03-29-2010, 04:25 PM
  5. E36 WTB: E36 M3 rear bumper, trunk and spoiler.
    By White325is in forum BMW Parts Wanted
    Last Post: 02-09-2010, 06:58 PM
