Results 1 to 16 of 16
Thread: Electrical problem
    Dec 2017
    Panama City
    1997 BMW 528i
    Electrical problem
    Something strange has happened, after installing my headlights with halos a couple months ago, the car has been constantly blowing hot air at the floor, and the HVAC panel does not work or light up at all. I didn’t think this was a problem before last Saturday, when it was raining hard and all my windows fogged making me unable to see and ultimately getting in a wreck. $700 later and we should be back up and running just now two different colors.
    Ive checked all fuses, everything seems to be in order there.
    A few interesting things to note, there are 4 connectors on the back of the HVAC panel, when the car is on, and the power & blue and white connectors are plugged in, it blows hot air down at full power, when the black connector is reconnected it goes back to being slow.
    It’s not consistent, it doesn’t start every time I turn on my car, I’d say 3/4 of the time it does it.
    I didn’t tap into much of anything for my halos, but just in case I will show what I did do and give a brief explanation.
    In the E-Box, I used the positive feed to a relay, and pulled power from a red with white stripe wire on the very left side.
    San Jose, CA
    1997 BMW 540i 6 speed
    So, this issue came up just after you did the wiring?
    Undo the wiring you did, and determine if your wiring is at fault.
    Dec 2017
    Panama City
    1997 BMW 528i
    Quote Originally Posted by edjack View Post
    This was the first thing I did, pulled out the wire from the + feed and the one that’s ticked next to white red/white wire and this didn’t change anything. Swapped out the HVAC panel with one I had spare as well and it still did not work.
    I **think** it came up after this, seems like the same timing but I cannot remember exactly when it started, but it seems like it was after the headlights.
    Dec 2017
    Panama City
    1997 BMW 528i
    Strange update
    Partially connected HVAC panel, and it lights up; but no control still. Probably not pertinent but just in case.
    Sep 2011
    Riverside, CA
    2004 330Ci
    Wiring diagrams for your IHK. Hope that helps.
    https://www.newtis.info/tisv2/a/en/e...ing-functions/
    Dec 2017
    Panama City
    1997 BMW 528i
    Quote Originally Posted by balidawg View Post
    I’ll take a look and see if anything comes of it, thanks for providing this! If not helpful now, surely it will be in the future.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    That is one nasty looking HVAC control face. Get me a cleaning!
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Dec 2017
    Panama City
    1997 BMW 528i
    Quote Originally Posted by StephenVA View Post
    LOL That was the old one out of the garage! My car is about to get a deep clean after all this stuff going on.
    Oct 2019
    FL
    1987 BMW 325es
    bump
    Dec 2017
    Panama City
    1997 BMW 528i
    Electrical problem
    So some new things, I was in the car with my fiancée a week or two ago and she mentioned how the car does not really blow while at idle speed but instead it gets faster as the car gets faster.
    I have also pulled two fuses, fuses 76 and and 11 I believe they were and absolutely nothing has changed..
    Anyone got any clues? I’m beginning to think this isn’t just electrical.
    San Jose, CA
    What is the battery voltage when the engine is idling?
    Dec 2017
    Panama City
    1997 BMW 528i
    13.5-14 volts. Sorry that took so long, didn’t get a chance to look last night I got in kinda late and have had a busy day today.
    San Jose, CA
    Can you control blower speed with the +/- button?
    Dec 2017
    Panama City
    1997 BMW 528i
    Nope, the controls are completely unresponsive. Won’t even light up.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    dead HVAC controler unit. New $500, but before you go and buy one, lift the passenger seat and check the electrical connectors under the carpet...
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Dec 2017
    Panama City
    1997 BMW 528i
    Connectors under passenger seat are okay.
    I have tried two different units, both of which I know have worked in the car previously and just tested another and it did not work either.
  1. Electrical Problem..
    By LaujPhem in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-15-2003, 03:49 PM
  2. Weird Electrical Problem (Extra Long)
    By Zippy M3 in forum 1991 - 1999 (E36)
    Last Post: 08-14-2001, 02:37 PM
  3. Weird Electrical Problem (Extra Long)
    By Zippy M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-13-2001, 08:28 PM
  4. fuse/electrical problem....
    By flyimages in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-24-2001, 10:15 AM
  5. fuse/electrical problem....
    By flyimages in forum 1991 - 1999 (E36)
    Last Post: 07-22-2001, 02:17 AM
