Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
Thread: Complete E39 M54 cooling system overhaul
  1. #26
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Remember you are looking at a 528 application. The process is similar but the Thermostat area and hoses are different. The water heater switches are on the frame rail near the steering column. Setting to "HOT" allows you to back flush the heater box in the dash so you get every bit of material out of the system. Necessary? Depends on how bad the coolant is. 90% just drain and refill with no issues reported.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
  2. #27
    May 2010
    Midwest
    E36M3/4 E39T&E61 E39M5
    Quote Originally Posted by BimmrMeUpSnotty View Post
    I never bother with that, but then again, my coolant is clean as hell as I always change it every year, distilled water and BMW coolant.
    Quote Originally Posted by StephenVA View Post
    Yes, I know Steve. I should probably do the flush just to get the green coolant out that the original/previous owner's shop used... I like my coolant BMW blue lol
  3. #28
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    I ran green Preston's in my old green wagon that I wrecked, for close to 4 years, never had a problem, just make sure you do a full flush then if you are switching back.
  4. #29
    Jun 2022
    Italy
    E39 530i
    Hello,
    Jumping into this topic as I have to replace the radiator on my 2001 530i automatic, EU spec (Italy). I have previously replaced all the coolant hoses after I have noticed a lot of coolant lost under the car in the garage (luckily). I did not see any need to replace the radiator back then, but now - 2 months later - i have noticed coolant loss in the driver side after the engine is heated up. It seems that there is a loss from the radiator. I guess I should have listened to the E39 community and replace the radiator as well when noticed weakness in the system
    On my previous replacement - I have filled up my cooling system with green alu-safe coolant. I was advised by my mechanic who changed the coolant that any blue or green would be suitable to fill up. There were no issues since then with the cooling capacity or any anomalies, but now that i will have to drain the coolant again, I would like to fill in original BMW coolant.
    My questions are
    1. Is there any way to completely drain the coolant - including the one from the engine - without undoing the engine bolt - near cylinder 2? I do not have a lot of space for this where I am working on my car - and I was thinking to somehow drain all the liquid only using front accessible radiator drain / hoses. I am open to any of your suggestions.
    2. I have ordered MAHLE Radiator for replacement - anyone has any feedback on using this? seems to be the same manufacturer as BEHR?
    3. I cannot find the BMW 1 Gallon bottle coolant in Europe but only BMW 83512355290 - anyone has any experience with this?
    Thank you!
    More details about my car:
    2001 530i - automatic. 120k KM (~75k mls)
    Recently changed in the cooling system
    - all cooling hoses (not plastic pipes, not cabin side hoses - they are looking good)
    - water pump - with Continental metal pump
    - all pulleys / rolls
    - expansion tank - after developing cracks
  1. e39 m54 cooling system overhaul a overview would be awesome
    By jharbert530 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-24-2017, 09:19 PM
  2. e39 528i Cooling System Overhaul Parts List - Complete or Not?
    By scottdodge in forum 1996 - 2003 (E39)
    Last Post: 07-26-2013, 05:24 PM
  3. E39 still over-heating after complete cooling system overhaul.
    By jayxsavage in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-11-2013, 09:53 AM
  4. 2002 e39 cooling system overhaul parts list
    By jasonstx in forum 1996 - 2003 (E39)
    Last Post: 07-08-2008, 05:20 PM
  5. Cooling System Overhaul Complete!
    By tminus3 in forum 1991 - 1999 (E36)
    Last Post: 05-11-2007, 10:39 PM
