Are there drain tubes on the bottom of the SCR tanks?
First, what’s a DEF tank? Second, go to www.newtis.info and enter the last 7 characters of the car’s vehicle identification number. Hit enter and bookmark the page. Then go to www.realoem.com and repeat the same steps. In realoem find the DEF tank. Note the first 4 numbers of the part #. The first 2 numbers indicate the system while, if I remember correctly, the second 2 numbers indicate the subsystem. Then go back to newtis and dig down first to the system and then the subsystem. That’ll give you info on the DEF tank maintenance and repair.
Ya know adblue, diesel exhaust fluid, def and why do you need to drain the tank
I have a problem with the DEF level sensor as do many others and I wanted to put in deionized water to dissolve the crystalization.
Thanks so much. I have the error code for erratic level sensor.
