Results 1 to 6 of 6
Thread: Bmw e46 roof not working
    Apr 2020
    manchester
    bmw e46 convertible
    hello again guys. spent some more time on the e46 roof and found that the problem seems to be with the module under the back seat. i can now drop the roof on the button but nothing happens when i try to close it although i have managed to get it to close once after pressing the release button the module under the seat. The rest of the time ive had to close it manually. Think i should also mention that the apron which lifts to store the roof isnt locking on the right hand (drivers) side when i close it. could this be the cause of the problem and is there a process to calibrate the cogs and cables in the seat module ?
    Jan 2016
    Ca
    2001 525it
    The main problem on these cars is the main wiring harness the runs up along the drivers side of the roof, wires break over time that is the first thing is would check
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Thread relocated to the model specific area.
    88M3 AW 43k miles Project FS
    Apr 2020
    Los Angeles
    BMW 330ci
    Mine quit working a few years ago. It was very hard to find someone to fix it. Nobody wanted to touch it. Turned out to be lose wires that cost around $500. I took it to Avus Autosport in LA. Excellent BMW specialists.
    Apr 2013
    Mill Valley, CA
    2003 330cic
    There are some excellent diagnostic threads in the vert section of e46fanatics.com
    Vert issues are usually the harness wiring, specifically above the driver's seat but often at each of the hinge points. You can patch, or replace the whole harness, which is not "hard", but takes a ton of time and patience. Without a doubt the longest DIY I have done.
    Also the gear on the locking motor (under the back seat) can get unseated or stripped. As a result the tonneau cover latches don't open and the system gets an error. You really need to get INPA to help diagnose.
    cowichan bay, bc, canada
    06 330ci zhp convertible
    Try putting pressure on the box under the rear seats%. Known fault that gear pops up. I used plumbing strapping and a small block of,wood to put pressure on it. Has worked fine for years%...
  1. Bmw e46 roof not working
    By spannerman0785 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-17-2020, 12:24 PM
  2. BMW E46 lights not working
    By giesta98 in forum 1999 - 2006 (E46)
    Last Post: 07-21-2018, 02:35 PM
  3. 2003 bmw 325i e46 sidemirrors not working
    By BMWHussey in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 10-04-2015, 03:50 PM
  4. M3 E46 convertible Hood/roof not working
    By riffz1 in forum 1999 - 2006 (E46)
    Last Post: 09-30-2015, 03:32 PM
  5. BMW E46 MFSW not working.
    By Johan Deon in forum 1999 - 2006 (E46)
    Last Post: 07-09-2014, 01:26 PM
