Hello all- I need to check the timing on my S54 and there is apparently two different tools- BMW # 119-140 (Camshaft Alignment Gauge) and 119-130 (Camshaft Alignment Tool) - that appear to serve the same function. The former is still available, the latter is not. #119-130 is labeled #1 and #119-140 is labeled #2 below. Does anyone know if you can just use 119-130 to time the cams?
Did you mean the latter is available? 130 is available, that is what you need to use (item #1 in your pic).
https://www.ecstuning.com/b-genuine-...caAlxOEALw_wcB
If you need help, follow Beisan procedure:
http://www.beisansystems.com/procedu..._procedure.htm
That said, to check timing you also need #5 to lock the crank at TDC for cyl #1.
The BMW TIS procedure does show both tools. But it's always been unclear to me what the exact difference it between tool -130 and -140.
Having said that. TIS shows -140 to check the current timing on the "Checking timing of camshafts" procedure. And when this needs to be adjusted, the "Adjusting timing of camshafts" procedure shows the -130 tool.
But the pin itself seems to be in the same position on both.
1998 BMW M3 3.2 Cabrio Alpinweiί III on Schwarz German spec 1 of 12
SMG SRA PDC AUC OBC GSM HK UURS IHKA FGR MFL
IG: https://www.instagram.com/iflok/
DO NOT use the aftermarket tools. I used an aftermarket tool and my timing was off. I then purchased the OEM tool and it was spot on.
BTW, I have a OEM tool for rent.
There’s plenty of people using these, although one aftermarket set doesn’t equal the other.
But unless they are way off, they should do the job.
The OEM tools are obviously favorable, but a totally different price.
I'm just speaking from experience. This was the kit I purchased (and returned) https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
That kit seems identical to all kits sold on Ebay/Amazon/etc.
Some just have a different color anodizing.
