Results 1 to 10 of 10
Thread: Advice on timing tools for S54 engine
    Jun 2013
    maine
    1999 bmw m3
    Hello all- I need to check the timing on my S54 and there is apparently two different tools- BMW # 119-140 (Camshaft Alignment Gauge) and 119-130 (Camshaft Alignment Tool) - that appear to serve the same function. The former is still available, the latter is not. #119-130 is labeled #1 and #119-140 is labeled #2 below. Does anyone know if you can just use 119-130 to time the cams?
    Aug 2017
    Menlo Park
    '05 ///M3
    Did you mean the latter is available? 130 is available, that is what you need to use (item #1 in your pic).
    https://www.ecstuning.com/b-genuine-...caAlxOEALw_wcB
    If you need help, follow Beisan procedure:
    http://www.beisansystems.com/procedu..._procedure.htm
    Aug 2017
    Menlo Park
    '05 ///M3
    That said, to check timing you also need #5 to lock the crank at TDC for cyl #1.
    Jun 2013
    maine
    1999 bmw m3
    Quote Originally Posted by mrgizmo04 View Post
    Yes, I mixed that up-140 is not available except in kits and are not BMW parts. I don't trust the knock-off kits.
    Sep 2018
    Maryland
    2001 M3 Coupe Track Car
    Quote Originally Posted by drewt1 View Post
    Tool ending 130 is what you need. And only ONE pin that comes with the tool. You also need the TDC locking pin.
    Like suggested some places do not get another pin and insert them both. They will get seized in there.
    The Netherlands
    DE-spec E36 328i/M3 cab
    The BMW TIS procedure does show both tools. But it's always been unclear to me what the exact difference it between tool -130 and -140.
    Having said that. TIS shows -140 to check the current timing on the "Checking timing of camshafts" procedure. And when this needs to be adjusted, the "Adjusting timing of camshafts" procedure shows the -130 tool.
    But the pin itself seems to be in the same position on both.
    IG:
    TX
    97 M3/4/5, MCS
    DO NOT use the aftermarket tools. I used an aftermarket tool and my timing was off. I then purchased the OEM tool and it was spot on.
    BTW, I have a OEM tool for rent.
    The Netherlands
    There’s plenty of people using these, although one aftermarket set doesn’t equal the other.
    But unless they are way off, they should do the job.
    The OEM tools are obviously favorable, but a totally different price.
    IG:
    TX
    97 M3/4/5, MCS
    Quote Originally Posted by MParallel View Post
    I'm just speaking from experience. This was the kit I purchased (and returned) https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    The Netherlands
    That kit seems identical to all kits sold on Ebay/Amazon/etc.
    Some just have a different color anodizing.
    IG:
  1. IL Looking to borrow or rent cam timing tool for S54 engines
    By Quick99Si in forum Great Lakes - US
    Last Post: 05-25-2012, 05:20 AM
  2. S54 timing tool
    By Spektrum in forum Tennessee
    Last Post: 04-24-2012, 02:08 PM
  3. E46 FOR RENT: S54 VANOS Timing Tool Rental
    By ltbong in forum Engines, Performance Parts & Software
    Last Post: 09-12-2011, 06:43 PM
  4. WTB or Rent Timing tool kit for M62 engine
    By brewmyown in forum BMW Parts Wanted
    Last Post: 05-28-2011, 09:31 AM
  5. Another ticking time bomb with S54 Engines? (rod bearings + ???)
    By Wayne@PelicanParts in forum 2001 - 2006 M3 (E46)
    Last Post: 05-13-2005, 02:02 AM
