Results 1 to 3 of 3
Thread: Help with codes? Vanos / Camshaft Postion sensor / Clutch switch (?)
    Mar 2019
    Santa Fe, NM / SoCal
    E90 M3 Slicktop
    Hey guys,
    ever since I bought my car (at times) it's had an inconsistent idle, where it hunts for revs between 750rpm and 1,000rpm. Sometimes, it's also been taking a while to crank. I took it to a shop to get inspected and got the following codes:
    000076 - DME: Electric throttle: signal, potentiometer, throttle
    00006B - DME: Electronic throttle: self-test
    000078 - DME: potentiometer, signal comparison
    00008F - DME: Electronics-box fan
    000050 - DME: Switch chain, frictional connection
    000016 - DME: Exhaust vanos, advance valve
    0000B9 - DME: Function, exhaust VANOS
    Here's a video I took, with the car revving up to 3.5k RPM. Let me know what you guys think.
    https://youtu.be/yMca-lUF3hk
    San Jose, CA
    00 750IL, 01 740IL
    Part of it if not all related to you throttle position sensors. There are 3 of them, either replace then all or figure out which one is bad. Start with the front throttle sensor, if that dont fix proceed to pedal, and last one is under the intake manifold.
    Edit: The last 2 codes could be exhaust hub tab, but I'm guessing here without solid evidence to back that up.
    Start with your tps and go from there.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    +1
    The S-54 is known for breaking off the exhaust tab on the VANOS, I wouldn't run the car until you have verified that both are still there. Also you can be looking at a worn-out VANOS, for the seals do go bad over time and it won't adjust as the DME requests.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  1. Code P0348 Camshaft Postion sensor A circuit High Input Bank 2
    By trader2318 in forum 1995 - 2001 (E38)
    Last Post: 07-22-2019, 12:13 AM
  2. intake mani removal required? to replace camshaft postion sensor
    By BostonBallao in forum 1991 - 1999 (E36)
    Last Post: 03-30-2008, 08:17 PM
  3. Anyone ever get code 1244 camshaft position sensor?
    By xjeeper in forum 1991 - 1999 (E36)
    Last Post: 02-13-2007, 11:12 PM
  4. Replies: 0
    Last Post: 02-13-2007, 09:57 PM
  5. Camshaft postion sensor help
    By gibby323 in forum 1991 - 1999 (E36)
    Last Post: 07-11-2006, 05:42 PM
