Hi everyone, I just finished putting in a refurbished engine and converting the car from SMG to stick shift and everything works well. The last phase is to get the software changed so that the car knows it's now a stick shift. Does anyone have any recommendations in Everett / Seattle area. Once I get this done I'll post up the process. Car is an E46 M3.
Thanks in advance.
Dalecan, which car are you working on?
E46 m3?
Sorry, yes 2005 E46 M3.
Dalecan, check your pm. Good luck.
thanks M3poser, email sent!
Other input still welcome.
Check 22rpd.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Thanks everyone. I"m using ECUworxs from the UK to do it remotely. I have the cable, just waiting for an appointment. Hopefully she will purr after this.
I am in the Los Angeles area and would like to find a shop that does the smg to manual conversion on my02 M3 - I found Lang in Lake Forest and they want $4000. Can anybody suggest a reputable shop at a reasonable rate ?
That's the only shop that I know that does this, or at least advertises they do it. You could phone around some BMW independent specialists. It is quite a lot of work thought, and I don't think it will be cheap to get a shop to do it.
thanks for the reply I have hunted on the internet and facebook and haven't found anyone local
OP, were you able to get this resolved? I'm putting together an SMG to manual conversion for my '05 M3 convertible and have everything figured except the software programming. I'm a ferry ride away in Poulsbo, Kingston area… Seems most geographic areas have a shop or two that does this on the regular but not the PNW?!? Finally some nice ///M weather though!
1989 535i - sold
Yup, I was just in touch with them. Def. planning to utilize their services when I'm through the mechanical portion of the project… Thanks!
My M3 rebuild is complete. I got my coding done remotely through ecuworxs. Martyn is a top guy and was very patient with my lack of coding knowledge. My cable took forever to get to delivered as there was something wrong with the barcode on it, but once here MArtyn was on top of it. Highly recommend.
Awesome! Really happy for you. Thanks for the update.
yay! i like seeing more and more 6spd m3s out there!
