Results 1 to 3 of 3
Thread: Unable to delete faults
    Denmark
    E36 325i '94
    Regarding my BMW E61 523i from 2007
    I recently got the "Restraint system" failure. Reading out the error codes I see 93FC and 93FD error codes,]Battery lead, positive/ground (monitoring of shielding), indicating a problem with the main battery cable. I have inspected the accessible parts of the battery cable, and see no problems.
    I have tried deleting the errors with INPA, I can only delete the regular error memory, INPA has the option of deleting the history memory, but that option fails. Deleting the regular memory does nothing, if I read out errors immediately after I get the same errors again, the error lights in the dashboard never disappear.
    I have also tried to delete the errors with the Android app "Deep OBD for BMW and VAG" but I get similar results as with using INPA.
    I am connecting to the car using an OBD k+DCAN cable.
    Does anyone know how I can delete the errors, or correct the problem?
    Error readout:
    SIM/SGM (Crash safety module):
    Error code: 93FC
    ACSM/MRS: Battery lead, positive (monitoring of shielding), Fault currently present, implausible measured values
    Environmental conditions:
    - Frequency: 9
    - Logistics counter: 40
    - Mileage/km reading: 194984 km
    Error code: 93FD
    ACSM/MRS: Battery lead, ground (monitoring of shielding), Fault currently present, implausible measured values
    - Frequency: 2
    Error code: 93B2
    ACSM/MRS: Safety battery terminal, Fault currently present, implausible measured values
    - Frequency: 1
    - Mileage/km reading: 197376 km
    The error 93B2 is from my previous attempts at diagnosing the problem, I disconnected the battery safety terminal, and reconnected it again, but I am unable to delete this error as well.
    Jul 2004
    Houston, TX
    36 Cylinders
    That essentially means the problem is still there, you may have to trace the wiring with a multimeter and find any faults before it will clear.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Denmark
    E36 325i '94
    That is what I thought as well, that just does not explain why the 93B2 error has not cleared as well, that error occured because I disconnected the Battery Safety Terminal, and I have since reconnected the BST, and cleared the error codes, but the error code remains.
  1. DIY: Complete ASC delete with no ABS light/fault!
    By 328iJunkie in forum E36 Common Problems and DIY Fixes
    Last Post: 04-10-2020, 10:04 AM
  2. Permanently Tune/Delete Fault Codes from ECU
    By V8Z4 in forum Engine Tuning
    Last Post: 05-14-2016, 10:34 PM
  3. X5 Valvetronic Fault - Dealer unable to repair
    By ramsesthethird in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 04-02-2007, 07:52 PM
  4. Built in Fault Code Reader!!
    By Mike325i in forum 1991 - 1999 (E36)
    Last Post: 08-23-2001, 08:36 PM
  5. Knock Sensor #2 Fault?! oh no!!
    By Brett in forum 1991 - 1999 (E36)
    Last Post: 03-03-2001, 09:37 PM
