Page 3 of 24 FirstFirst 12345678910111213 ... LastLast
Results 51 to 75 of 599
Thread: My 1999 M3 Progress Thread
  1. #51
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Very thorough. Maybe the brakes are also used on some other car or maybe ate still sells them but without the logo. Red brakes are popular these days.
  2. #52
    Oct 2015
    Richmond, VA
    99 M3 Coupe, 99 Carrera
    Excursions into air duct discussions here: https://www.bimmerforums.com/forum/s...-Air-Duct-Help
    Turns out 17112227690 isn't compatible withe LTW/GT air duct. Ordered to complete the front air ducting:
    51-71-2-253-303 & 17-21-2-227-344 - Oil cooler air ducts
    51-71-8-135-939 - Air duct bracket
    Also ordered these to complete the underbody ducting. Most of these parts were found on the Euro E36s. Pretty sure I got the right stuff but there might be some trial and error here:
    51-71-2-491-567 - Center underbody coating
    51-71-2-490-230 - Underfloor coating bracket
    11-81-1-095-700 - Stop buffer for x brace
    51 71 2 489 775 - "Screening" - this should attach next to center underbody panel and cover the side of the oil pan.
    07-11-9-916-949, 07-12-9-904-231, 07-11-9-901-299 - nuts and bolts to install al this
    Since I live in a mandatory front plate state that is strictly enforced, I ordered the factory front plate set up:
    51-11-2-265-632 - Impact strip on front bumper
    51-18-1-908-062 - front plate bracket (I think this is off an E34 as I didn't see one listed for an E36)
    07-14-3-448-498 x 6 - screws for the above
    51-18-1-852-299 x 2 - grommets
    46-63-7-651-465 - nuts for the screws
  3. #53
    Jul 2012
    Santa Barbara
    95' M3,
    It seems to me like you are going through this car in a very thorough manner, but my I ask why you went with those calipers since no ///m or anything? Were the ones you have too far gone to rebuild with new seals?
  4. #54
    Oct 2015
    Richmond, VA
    Quote Originally Posted by cfletch13 View Post
    The calipers were exactly identical sans logo- every curve, crevice, indentation was exactly the same. Would have I preferred they have the logos? Yeah, but functionally there's no difference here. If I had decided to rebuild my old calipers to this standard, they'd still be off the car while I wait for my powdercoating guy to finish them. I value the time saved being able to take the old part off and bolt the new one right back one. It took an afternoon to do all the brakes instead of a week, and I got a core refund.
  5. #55
    Oct 2015
    Richmond, VA
    Got some tires mounted. Yokohama Advan Fleva V701. My friend runs these on her MR2 Spyder. They seem to work really well among smaller lighter cars. Normally I run the Michelin PS4S on my cars which is an amazing tire, but frankly it's way overkill for a car with 240 horsepower and around 3000lbs and probably would take some of the fun out of it. A PS4S is near the equivalent of a racing slick in 1999.
  6. #56
    Utah
    '67 HD Electra Glide
    What kind of lift do you use? Thanks.
    1998 E36 M3/4/5 - 1993 Spec E36 325is
    Crew - #52 - SCCA World Challenge TC
    MoTeC Man
  7. #57
    Oct 2015
    Richmond, VA
    Quote Originally Posted by rossiski View Post
    Quick Jack BL-5000SLX
  8. #58
    Oct 2015
    Richmond, VA
    Installed:
    51211928850 - door striker bolts
    51218105511 - door latch striker
    Details why here: https://www.bimmerforums.com/forum/s...r-hard-to-open
  9. #59
    Oct 2015
    Richmond, VA
    Decided to get the heater hoses over with. To make the job easier I removed the intake manifold. Replacing:
    13411435781 - Idle control valve hose
    13411733217 - idle control valve gasket
    11611740069 x 2 - Intake manifold gaskets
    11611703779 - Intake manifold cover gasket
    11611716174 - throttle body gasket
    13541703693 - ASC to throttle body gasket
    13541703945, 13541703865 - coolant hoses to throttle body
    64211394292, 64211394291, 64211394293 - hoses to heater core
    Bosch starter
    ECS fuel injector installation kit (OE clips, fuel rail bolts, Rein o rings)
    Anything else you guy would replace? Obviously have a lot of access right now. Already gave the ICV a good clean. There's no codes, so I don't see the need to replace sensors. Vanos oil line is an obvious one but it isn't leaking. I'm not too worried as I will be removing manifold again relatively soon to install modifications.
  10. #60
    Oct 2015
    Richmond, VA
    This arrived from the Fatherland today (after 2 months of delay). OEM GT2 Heckspoiler. Heckspoiler!!!
    It does need mending though
  11. #61
    Jan 2003
    Kansas
    97M3, 11S4, 111M, 17X1
    Let me guess, you purchased this spoiler used from a novice who does not know proper packaging techniques. Hope it was insured. Sorry to see this happen.
    Black Magic Variant
  12. #62
    Apr 2020
    DFW
    1998 BMW M3, 1998 328is
    that is a lot of work put into it bro, great job.
  13. #63
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Quote Originally Posted by Black Magic View Post
    No, it was like that in the for sale ad.
  14. #64
    Oct 2015
    Richmond, VA
    Quote Originally Posted by Braymond141 View Post
    I see you also browse German eBay....
  15. #65
    Jan 2006
    Oakhurst, CA
    Quote Originally Posted by sirhodjibob View Post
    Ja. My wife is from Koln. I get to use her for translation and her family address if a seller won't ship direct to me.
  16. #66
    Texas
    E36s
    I am in the process of restoring a Titanium Silver version of essentially the same car... 99 with power seats, audio, with ~90k, straight body, no wrecks, all matching VINs, etc. I am a few months behind you in work, though.
    My 99 has a dealer installed rear spoiler as well. I've been wanting to delete the 3rd brake light from the rear package shelf, so it's really cool to see someone with the same line of thought. Do you happen to have any more pics of the install? Or of that area in general? I'd like to keep the speakers, so it's a little disappointing that the rear package shelf isn't available with the cutouts.
    Im also curious what the bolt pattern looks like for your dealer installed spoiler? Mine is cracked, so Im in the process of replacing it with an OEM spoiler... but after removing the dealer one, it looks like the bolt pattern is different from the standard OEM spoiler. Not the end of the world, but unfortunate to have to drill new holes in the trunk. Especially given that the rear mounting holes are very close to each other, so the new holes will be right next to the old ones.
  17. #67
    Oct 2015
    Richmond, VA
    Quote Originally Posted by JamesL71 View Post
    Unfortunately I don't have any more pics, but the install is fairly straightforward. You do have to remove the side bolster on the rear seat which just lift out and the C pillar trim pieces which are very easy to break the tabs when removing. They each attach with 4 clips. I ended up replacing these as mine broke. If I remember right the brake light itself is only held on by one bolt which you access from the trunk. You may also need to replace 51-46-8-130-863, which is attached via 4 clips where the shelf meets the rear seats. For what it's worth the new shelf does come outlined of where you need to cut for the speakers, so I may revisit this.
    Do note I also replaced the rear glass to correct the defroster lines around the now missing brake light. If you don't do this it will look off in my opinion. The other option would be to keep the shelf brake light, and go for a spoiler without a light instead.
    A far as the spoiler I had no idea there was a difference between what the factory installed vs the dealer. I am happy to take some pictures of how mine is mounted if that would help.
  18. #68
    Oct 2015
    Richmond, VA
    Got all the radiator ducting wrapped up. I ended up needing to replace the side ducting around the radiator as it wasn't compatible with the oil cooler duct. The part numbers for these are 51712256543 and 51712256544.
    I suppose I should probably get an oil cooler considering the amount effort that went into getting ducting for one....
  19. #69
    Oct 2015
    Richmond, VA
    I ordered and installed ECS's clutch pedal kit. It's quite comprehensive and really replaces everything (pedal, UUC bushings, spring, clips, etc) although it was short one measly grommet for the brake pedal spring. I also for good measure installed AKG's delrin brake pedal bushings, an FTE clutch master cylinder, and FTE slave cylinder.
    I have to say this job was a pain. Just remove your driver's seat and get it out of the way. Once you've done it it's straight forward but space and visibility are tight. For this reason I recommend replacing as much as you can down here so you don't have to do it again.
    Before:
    After:
    As you can see the brake pedal pad is quite worn on the side, so a new one has been ordered (35211160422). And yes I am missing the screw cover cap for the hood release. I ordered a new one and it immediately fell off so...
  20. #70
    Oct 2015
    Richmond, VA
    Next big jobs up:
    -New front control arms with OE bushings
    -Remove transmission and replace detents, clutch, flywheel, and a whole bunch more
  21. #71
    Oct 2015
    Richmond, VA
  22. #72
    Oct 2015
    Richmond, VA
    @JamesL71 here is the spoiler mounting:
  23. #73
    Oct 2015
    Richmond, VA
    Anyways, this round of parts should wrap things up until winter (I think). Here's what's going in:
    Suspension:
    -rebuilt & powdercoated OEM front control arms courtesy of BRaymond141 (these seriously look awesome)
    -new front control arm "lollipops" with new Lemforder bushings
    -31111137888 & 31111114348 new bolts and washers for the lollipops
    -32216769539 & 31106774714 new nuts for the ball joints
    -Rogue Engineering rear trailing arm bushings. These are their own rubber bushing design and eliminate the need for limiters
    -33303411877 & 33303411878 new RTAB brackets
    -33326760386 x 6 RTAB bracket bolts
    Driveshaft:
    Ordered ECS's Universal Flex Disc Kit. Includes:
    -new giubo
    -new center shaft support bearing
    -new driveshaft centering sleeve
    -installation hardware
    Transmission related things:
    -Bimmerworld detent repair kit
    -OE Sachs Clutch & pressure plate
    -07119906045 x 6 pressure plate bolts
    -OE Luk Dual Mass Flywheel
    -11222243051 x 8- flywheel bolts
    -OE pilot bearing
    -OE Sachs throwout bearing
    -23111224845 throwout bearing guide tube
    -21517570284 - clutch release arm spring
    -23117531355 x 4- bolts for guide tube
    -21511223281 - stainless steel clutch fork pivot pin from an E31/E39
    -23111224799 - output shaft seal
    -23211224820 - input shaft seal
    -OE rear main seal
    -OE crank seal cover gasket
    -Rogue Engineering transmission mounts (already installed actually) with MSportParts transmission tunnel insulation brackets (a must have if your insulation is disintegrating and rubbing on your driveshaft. No more insulation particles getting into your eyes when you're under your car!!!!)
    Shifter:
    Ordered ECS's shifter rebuild & upgrade kit. Includes:
    -Turner polyurethane shift arm bushing
    -ECS teflon shifter bushings
    -URO shift rod join and bearing pin
    -few other odds and ends
    In addition I ordered:
    -25117527247 - shift lever
    -23121282394 - shaft selector seal
    -AKG Motorsports DSSR
    Other:
    ECS Downpipe/catalytic converter installation kit (for exhaust reassembly after transmission install)
  24. #74
    Texas
    E36s
    That does help, thank you. Although, it looks like we have different spoilers. Im not sure where the dealer installed one on my car came from... perhaps it is from a sedan, instead of a coupe. Or it's possible the first owner installed an aftermarket spoiler.
    Btw, Im doing my clutch pedal next weekend. Just received all the parts from the ECS kit, although I have a Mason Engineering pedal. Looks like the install is going to be fun :\
    Great work on your car. It's giving me good ideas.
  25. #75
    Oct 2015
    Richmond, VA
    Nice. I didn't learn about the Mason pedal until I was midway through installation otherwise I might have gone that route.
    If you did the ECS kit I would order an extra grommet for the brake pedal spring since its short one- mine disintegrated as soon as I touched them. Part #35411113728
  1. 3rd Time's the Charm: Ryan86's 1999 M3 Convertible Build Thread
    By Ryan86 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-03-2020, 07:21 AM
  2. E46 M3 GTS-3 Build and Progress Thread
    By u2usual in forum Track Car Builds
    Last Post: 09-12-2015, 10:27 PM
  3. Track Project M3 - (Progress Thread) by Sonic MS
    By mmzcee in forum BMW Rides & Events
    Last Post: 07-21-2011, 04:10 PM
  4. M3 progress thread
    By Diaonic in forum New England - US
    Last Post: 09-13-2006, 05:06 PM
  5. FS: 1999 M3 Dakar/Black
    By Pras in forum BMW Cars For Sale / Wanted
    Last Post: 08-01-2004, 01:25 AM
