Page 19 of 24 FirstFirst ... 9101112131415161718192021222324 LastLast
Results 451 to 475 of 599
Thread: My 1999 M3 Progress Thread
  1. #451
    Oct 2015
    Richmond, VA
    99 M3 Coupe, 99 Carrera
    Quote Originally Posted by samy01 View Post
    Has this head been checked for cracks, and if yes what method did you use?
    Looks like cracks cyl 3 spark plug hole to rear intake valve seat
    What the hell are you talking about?
  2. #452
    Earth
    E34 M5, E36 M3, E90 M3
    Quote Originally Posted by sirhodjibob View Post
    lol. Glad to know I'm not the only one who thought this.
  3. #453
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    lol. Reminds me of the diabetes bit on Family guy.
    https://www.youtube.com/watch?v=t0H2fH3K044
  4. #454
    Oct 2016
    Austria
    e36 323i, M3 3.2
    about the cylinder head in post 441
  5. #455
    Jan 2006
    Oakhurst, CA
    I can only assume you're looking at the natural casting/machining marks. There are no cracks. I think that is quite clear in the post blasting work and then subsequent machine shop work.
  6. #456
    Oct 2016
    Austria
    e36 323i, M3 3.2
    Quote Originally Posted by Braymond141 View Post
    what method did you use to verify that?
    dye penetrant? visual inspection?
  7. #457
    Jan 2006
    Oakhurst, CA
    My eyes. If you can’t verify the head condition yourself, have the machine shop doing the work go over it. Pressure testing is how they will do it if visual isn’t enough.
  8. #458
    Oct 2015
    Richmond, VA
    Soon.
  9. #459
    Jan 2006
    Oakhurst, CA
    Looks like cyl 1,2,3,4,5,6 are cracked. How was this tested?
  10. #460
    Aug 2003
    USA
    E36 M3, 11 X5d, 16 F31
    Lol. Good one.
  11. #461
    Oct 2015
    Richmond, VA
    hahaha. I can just use RTV to patch it up right?
  12. #462
    Jul 2021
    FL
    1999 E36 M3, 2013 E92 M3
    Lol! Love it!
  13. #463
    Jan 2006
    Oakhurst, CA
    lol.
    Head looks good. What headgasket did you go with?
  14. #464
    Oct 2015
    Richmond, VA
    Had originally purchased an Elring from Rockauto, but ended up getting a factory BMW one from the dealer. Better safe than sorry on a part like that.
  15. #465
    Oct 2003
    New Jersey
    E36 M3 / 991.2 911
    I was going to make a joke / question about the cardboard but you folks already beat me to it. Haha.
    Looks awesome!
  16. #466
    Oct 2015
    Richmond, VA
    doh that went right over my head
  17. #467
    Jan 2006
    Oakhurst, CA
    Factory is Elring. The issue is if it is actually branded Victor Reinz or Elring. BMW sold doesn’t mean anything, it’s either going to be Elring or Victor Reinz if new stock.
    Victor Reinz bought out Elring and anything after 2020 is likely to VR inside the Elring packaging. If you have VR, consider looking for an original Elring gasket. They are a better gasket. Having the BMW logo on a VR gasket is a downgrade.
  18. #468
    Sep 2002
    Vancouver
    98 M3
    I would just use masking tape TBH.
    - 98 m3, techno/anthrazit cloth, 124k and officially worthless - 89 m3, alpine/black 143k and officially old - 2000 323it, tiag/grey, 169k and officially boring
  19. #469
    The Netherlands
    DE-spec E36 328i/M3 cab
    They did a cracking job.
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
  20. #470
    Texas
    E36s
    Did you ever receive the passenger front door cards you ordered a while back? Just curious what the status is on those...
  21. #471
    Oct 2015
    Richmond, VA
    I did. I have all new front and rear panels, just waiting for ASC Fabrics to get M Cross fabric back in stock. Been very busy with work and it's been tough to find time to work on the car, but will have time around Christmas.
  22. #472
    Oct 2015
    Richmond, VA
    Much overdo update. Long story short, had a change at work and moved. All good things, but had to take a break from working on the car. Had some minor things up on the 996 that needed sorting too.
    Had the following vapor honed at UrbanEast Cycle in Lorton:
    -oil filter housing
    -oil pan
    -engine mount brackets
    -timing cover
    I also had Turner Motorsport front subframe reinforcements welded in, then had the front subframe powdercoated by Extreme Powdercoating in Springfield. They did a phenomenal job, highly recommend.
    Lastly had GTPeace weld in the Turner Motorsport oil pan baffle kit. I like this kit as it uses the OE BMW trap doors from the E30 M3.
    You'll notice the steering rack looks a bit different. That is an OEM BMW manual rack (part # 32111138198) I picked up used off Schmeidmann and is off a Euro market 316i. Now this was obviously used in an economy application and not a performance one so I am holding onto the ZHP rack for now as I have no idea if it's actually any good (good chance it isn't). But the thought of further simplification and weight reduction made it worth trying to me. Race German sells the correct size accessory belt if you are interested.
    Laid everything out and am working through the pile. Naturally as I am going through I'm finding more hardware to order, so at the moment just waiting for a few parts to arrive at the dealer.
  23. #473
    Oct 2015
    Richmond, VA
    Cylinder head is ready to go back on. Will install the cams on the car as with the Schricks it is tough, if not impossible, to torque the head studs if they are installed
    Installed:
    Supertech single groove valves x 24
    Supertech Valve stem seals
    Supertech single lock valves
    Supertech valve lock keepers
    11341403709 x 24 - Valve Springs
    11341432453 x 24 - Valve Spring Retainers
    11341403612 x 24 - Valve Spring Seats
    New bronze guides on exhaust side
    785501 - Supersprint M52/S52 headers
    Elring exhaust manifold gaskets
    11721437202 x 24 - N5X manifold nuts
    11127593376 x 24 - N5X manifold studs (makes install a breeze)
    NTK O2 sensors x 2
    11317838675 - INA primary chain tensioner
    Elring primary tensioner gasket ring
    11121717432 - water flange
    11121738963 - water flange gasket
    07119906123 x 2 - water flange bolts
    Uro thermostat housing (quality seems much improved over the one I bought a couple years ago)
    423675 - Borg Warner 75*C thermostat
    Elring thermostat housing gasket
    Elring thermostat o ring
    12141703221 - camshaft position sensor
    12141748398 - camshaft position sensor o ring
    13627545338.- camshaft position sensor bolt
    13621703993 - coolant temp sensor
    07119963130 x 2- temp sensor & water hose connector gasket ring
    11121740396 - water hose connector
    MSportParts Schrick intake manifold gasket
    I did also replace 11121735180, the oil pressure noreturn valve as it does have an o ring you can't purchase separately. Question- does orientation and tightening spec matter for this? I just tightened to reasonably snug, obviously don't want to over tighten as goes into the aluminum head.
  24. #474
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    Are you still using stock hydraulic lifters? I went with Perrys solid lifter conversion in the S52 that is in my HPDE car and they are well worth the time to install and adjust.
    https://www.alien-engineering.com/pr...nversion-shims
    [IMG][/IMG]
  25. #475
    Jul 2021
    FL
    This thread serves as such a great referece point and road map for newer owners like me. The attention to detail and listed part numbers are invaluable. Thank you and hats off to @sirhodjibob for documenting your work.
    Curious... any plans to coat the headers?
  1. 3rd Time's the Charm: Ryan86's 1999 M3 Convertible Build Thread
    By Ryan86 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-03-2020, 07:21 AM
  2. E46 M3 GTS-3 Build and Progress Thread
    By u2usual in forum Track Car Builds
    Last Post: 09-12-2015, 10:27 PM
  3. Track Project M3 - (Progress Thread) by Sonic MS
    By mmzcee in forum BMW Rides & Events
    Last Post: 07-21-2011, 04:10 PM
  4. M3 progress thread
    By Diaonic in forum New England - US
    Last Post: 09-13-2006, 05:06 PM
  5. FS: 1999 M3 Dakar/Black
    By Pras in forum BMW Cars For Sale / Wanted
    Last Post: 08-01-2004, 01:25 AM
