Hello all,
I just brought my 2010 z4 out of winter storage. After the first long drive, I noticed that the side roundel, just the emblem part and you can see where the glue was, had fallen off and was gone. What size roundel do I need to replace it? I see 78 and 82mm. It looks like I cannot get one with for a trunk or hood because this one is flat with glue (no posts on it).
Thank you.
I have had to replace everyone of mine. The sticker part just falls off. Annoying!!!
This is what you need https://www.fcpeuro.com/products/bmw...z4-51147044207
To remove the old one I used a thin plastic strap that was used to hold a pallet of boxes together. Slid it behind the roundel and yanked. Hard. Popped right off. You may need to order a grommet or 2 to hold the new roundel in.
Hmmm. I only lost sticker part. My silver area is flush. There are no pins or holes or anything that I can see. I can see a dollop of glue. That was why I was looking for the mm size of the emblem. Maybe there is a sticker badge or even a knock off I can buy rather than spending the full price ...
You can find stickers on ebay. I wouldn't do it. But if you have a steady hand and can apply it straight with no bubbles. May be worth a try. Just measure the the area of the roundel for the size.
I took the measurement. It is 60mm. I don't see any reason not to try and $10 sticker vs a $40 emblem.
The sticker was a raised one and worked well and is straight. The only problem is that it is slightly too small, which means I have a small silver ring around the emblem. I think the real size was 64mm. It looks okay though and since you never see both sides of the car at the same time, it is not really noticeable.
Cool, glad to hear it worked out.
