Results 1 to 3 of 3
Thread: Turbo M54B30 2003 Z4 Roadster (E85 chassis) Build (Bottom Mount with AC)
    Mar 2014
    FL
    Turbo '03 Z4 3.0i 6MT
    Hi, all. Sharing my '03 Z4 3.0i bottom-mount turbo build.
    Brief overview:
    -MS43 ECU
    -Has air conditioning
    -CX racing GT35R journal bearing turbo
    -E83 X3 2.0d Luk clutch disc, eBay ClutchMax flywheel and pressure plate (needs to be installed; currently running a slipping Valeo 835101)
    -M50 intake manifold and fuel rail (return is welded up)
    -Bosch 0280158123 630cc injectors
    -Bosch 0261230191 MAP sensor (before that, I used a B6 Audi S4 MAF sensor)
    -Precision turbo PW46 46mm wastegate
    -EMUSA Intercooler 25in. (total length; core length is 18in.) x 12 x 3 (2.75in. core)
    Turbo Specs (CX racing GT35R journal bearing)
    • Compressor housing - .70 A/R
    • Turbine housing - .63 A/R
    • Compressor Wheel 61.3 /82 mm
    • Turbine Wheel 62 /67.8 mm
    • 4in. inlet and 2.5in outlet
    Link to my wheelwell page with tons more photos and info:
    https://wheelwell.com/vlad-belsky/2rj3/2003-bmw-z4
    List of items purchased and costs for the build. Items in red need to be installed. Needs a new clutch because the Valeo 835101 kit I have in it now does not hold the torque.
    Turbo Oil/Coolant feed
    • Rally Road Feed line (bottom mount)- $33
    • Rally Road Vanos bolt adapter to AN4 line- $33
    • M14x1.5 to 3/8 barb (coolant to block)- $9
    • 1/8 npt to 3/8 barb (coolant to lower rad hose)- $5
    • 36 mm coupler with 1/8npt hole- $10
    • Drain line (5/8 in pushlock hose and 3/4in heat shielding)- $20
    • 5/8in weld-on aluminum bung for oil drain- $5
    • Oil pan baffle kit and oil pan gasket- $204
    • 10ft 3/8in ID ss braided teflon line- $40
    Clutch
    • E83 X3 2.0d Luk clutch disc (part # 21207553770) and
    E60 550i pressure plate (from Luk kit with BMW part # 21207573789), ended up using only the disc- $340
    •ClutchMax S52/M52 15lb chromoly flywheel (surface needs to be machined 0.020in to accomodate the E83 diesel disc) w performance pressure plate (70% more clamping load, from their stage 3 kit) - $240
    • 22-spline clutch alignment tool - $8
    • Pivot pin (brass) - $18
    Intercooler
    • 2.5in Pipe kit $72
    • Intercooler $80
    • Intercooler mounting materials - $20
    • Extra 2.5in 90 elbow - $9
    Fuel System
    • Bosch 0280158123 630cc injectors - $250
    • Injector spacers - $40
    Bosch 0261230191 MAP sensor - $40
    • Deatschworks DW200 255lph fuel pump- $86
    Exhaust
    • Manifold ($140 including labor to machine it)
    • VHT 2000F paint- $20
    • Dump tube and downpipe starter fab + material - $140
    • T304 stainless 3in V band clamps/flanges x 3 - $54
    • 8FT 304 stainless 3in pipe - $60
    Turbo
    • Turbo - $300
    • Rally road E46 turbo engine mount arm w FEBI 15786/274111 engine mount -$180
    • Precision Turbo PW46 46mm Wastegate - $350
    • TiAL-style (Tial BV50 replica) 50mm Blow Off Valve - $54
    •-11lb spring for BOV - $15
    •Genuine Tial O ring for BOV - $5
    Air Intake for Turbo
    • 4 in to 2.5 in 45 degree elbow/coupler - $10
    • 2.5in inlet cone filter - $14
    Gaskets/Misc
    • Exhaust manifold gaskets (BMW part #11621728984)- $18
    • Copper spray Permatex 80697 - $10
    • M7 exhaust nuts part #11721437202- $10
    • Engine/trans mounts - $45
    • Spark plugs NGK BKR7E (set of 6) - $18
    AEM Failsafe 30-4900 wideband/boost gauge- $300
    Fabrication costs
    • Oil pan modification labor- $100
    • Fabrication labor for exhaust, charge piping, and air intake- $650
    Total:
    $4045 USD
    Nov 2017
    Cincinnati
    1999 BMW Z3 M Roadster
    Very cool rig... I love your approach to the build! It's simple, clean, and very well done.
    Z3///M Roadster | GC Sleeves | TCKline 450lb (F) & 700lb (R) | Koni S/A | Porsche 996 4-Pots | CSL 345mm (F) | e38 328mm (R)
    Mar 2014
    FL
    Quote Originally Posted by Meeners View Post
    Thank you!
  1. Turbo E85 Z4 Roadster Build- Bottom Mount w/ AC
    By VladBelsky in forum Forced Induction
    Last Post: 10-18-2019, 04:54 AM
  2. How much is jut the Hardtop worth for a 2003 Z4 Roadster
    By Roady in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 05-11-2019, 03:23 PM
  3. Replies: 0
    Last Post: 03-27-2019, 11:03 AM
  4. Z4 E85,E86 eBay - NO RESERVE - 2003 Z4 Roadster - NO RESERVE - 65k miles 5-Spd
    By Enemy in forum 3 series & Z Series
    Last Post: 06-13-2012, 08:27 PM
  5. 2003 z4 Roadster-25K Miles-5 Speed - So Cal!
    By Froggie in forum 3 series & Z Series
    Last Post: 04-29-2009, 11:50 PM
