Results 1 to 5 of 5
Thread: E36 rpm drop
    Mar 2019
    Laurel Mississippi
    Dodge magnum ,e36
    E36 rpm drop
    Hi guys, I'm new here and I have a concerning problem. my 328i automatic under full acceleration in 3rd gear it will climb the rpms just fine then gets past 4,500 it drops down to 4000 rpms real slow and then starts climbing again. While all this is happening it is still accelerating at a pretty constant speed. This happened while going up an incline just in case that makes a difference. Some guys told me it was normal but no other car I drove did this .
    Jun 2010
    NY
    1997 328i
    Yeah, after 3rd gear it will shift into 4th gear, so it sounds normal. Why do you think this is an issue? did you not know it has 4 gears?
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    Or torque converter locking up as it's supposed to and yes all automatics do that.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
    Mar 2019
    Laurel Mississippi
    Dodge magnum ,e36
    Why would 4th gear engage at only 4,500 rpm if I'm at full throttle and if so why is there only a 500 rpm difference between the 2 gears.
    Alright thanks bro just wanted another opinion on it.
    Jun 2010
    NY
    1997 328i
    Well the computer decides when to shift, it won't necessarily redline each gear.
    If you want to have a little more umph try D3, that is sport mode but it won't shift into 4th. Let go of the gas and push the shifter into D to pull 4th.
  1. E36 Vortech Surging, rpm drops, Air coming out of filter
    By AspenM3 in forum Forced Induction
    Last Post: 02-17-2015, 04:00 PM
  2. M3 E36 - rpm drop when blip throttle (cold engine)...video
    By foler in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 02-21-2014, 03:16 PM
  3. The RPM drops when the clutch is pushed down
    By Geoff.T in forum 1983 - 1991 (E30)
    Last Post: 02-12-2004, 03:37 AM
  4. RPMs Drop when clutch pressed
    By MikeV in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-24-2003, 01:08 AM
  5. RPMs Drop During Hard Braking... Is this Normal?
    By surfer123 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-13-2003, 07:52 PM
